Removing grips
Fossil Fred
Removing grips
Post by Fossil Fred »
G'day All,
It's been a very long time since I posted, mainly due to being rather disgruntled that my BMW Dealer can't or won't fix the constant vibrations on my '04 model.
However, I've decided to try and minimise the effects rather than run it over a cliff. So, can anyone give me some tips on removing the grips? I'm a bit concerned about wrecking the heated grip elements.
I'm intending to fill the bars with shot and fit gel-grips. Desperate times call for desperate measures.
Cheers
Fossil
Post by DJ Downunder »
BP explained once how he did his...he used a sharp Stanley type knife..you know the ones you can snap off the blade when the edge gets blunt...box cutter..is that what they're called.
Anyway..he said he just started at one end and started to cut while pulling the two bits apart so he could cut the rubber without cutting the wires of the heated grip..slow and careful.
Good luck...let us know how it goes.
big papa
Post by big papa »
'07 R1200RT
vinman
Post by vinman »
There's a way to do this without cutting the grips. I'm not sure how though. Last year I had a local shop swap out the stock handlebar and put on a rockster bar. They re-installed the same grips and grip heaters. Maybe some compressed air and a little lube sprayed in between the grip and heater element?
"Be a man and face the fire. Make something ugly into something beautiful." Unknown taxi driver.
big papa
Post by big papa »
Yeah, I have heard of using air. I was looking to specifically change out the grips. I have gel grips now. I hated the stock ones.
'07 R1200RT
bimrluvr
Donating Member #: 429
Post by bimrluvr »
big papa wrote:Yeah, I have heard of using air. I was looking to specifically change out the grips. I have gel grips now. I hated the stock ones.
Hey BP,
Can you give details about the gel grips you put on? How do you like them?
Doing everything I can to prevent/reduce carpal tunnel and tennis elbow and I have to replace my grips anyway to fix my heater connections. Thanks.
#429 (in for life)
'06 Silver R1200RT
big papa
Post by big papa »
I just went to the local yamahahondazuki dealership and looked at all the aftermarket sportbike grips. You have to buy 2 packages and use the large diameter grip from each package. For me, I just hated the shape of the stock grips. I did notice the heat comes thru even more with these grips. There were alot of grips to choose from. Just find the shape and feel you like.
'07 R1200RT
jb44
Post by jb44 »
I have been using foam grip covers like these for two years...
http://www.beemerboneyard.com/foamgripcov.html
No need to remove original grips, and the heat still comes through.
I originally purchased the grip wraps from a dirt bke shop, but recently bought the ones from the "Boneyard" as a replacement.
jb
bono1151
Post by bono1151 »
What are the options for replacing heated grips? Where did you buy them from? I would like to replace mine but I’m having a hard time find the proper replacement.
03 R1150R
2005 VW passat TDI
1995 Honda Odyssey
T97
Post by T97 »
I just took a set off of a Concours and it was surprisingly easy.
I pumped my compressor to about 90 psi, put on the air gun and extension. I took off the end weights, peeled the outside up and inserted the air gun extension as far as I could.
I let loose with the air while simultaneously pulling from the inside collar area of the grip. They both popped right off.
circuitrider
Removing grips
Post by circuitrider »
I removed the grips on my R without damaging them. I found that the rubber is glued to the heated grip sleaves only at the ends. I removed the bar-end weights and rolled the rubber of the grip back while carefully cutting the rubber where it was glued to the sleave with a #11 exacto knife. After both ends where cut free I stuck the nozzle from my air compress under the edge of the rubber. A blast of air from the compressor expands the grip and it slips right off. Compressed air also works well for installing the new grips.
The old grips where still completely intact. I gave them to a friend to reinstall on her 1150R.
If you love your motorcycle, set it free.
If it comes back to you, you've probably highsided!
sandu
Re: Removing grips
Post by sandu »
hello friends.
tell me please how to know if my bike has heated or non-heated grips?
I have to replace them, but do not know which one I should order.BTW, tell me please how to order only the rubber on the grips?
thanks
ekyang
Re:
Post by ekyang »
T97 wrote:I just took a set off of a Concours and it was surprisingly easy.
Here's a Youtube video on how to use an air gun to pop off your grips. http://www.youtube.com/watch?v=buwXnnHW ... ig&index=1
jrsndman
Donating Member #: 720
Re: Removing grips
Post by jrsndman »
Jim
2008 K1200GT
2002 R1150R (Black) - SOLD
2000 Suzuki Bandit 1200S
Lifer # 720
