Jumpstart terminal retrofit
Lean Angle
Post by Lean Angle »
Just put it in yesterday on my '02 beak. Only 4 oem parts were needed:
1. 61137671355 Bracket
2. 61137671354 Terminal Screw
3. 61137672395 Protection Cap
4. 07119931050 Flat Washer
Less than $20 for all.
First remove the plastic starter cover, replace the brass stopper on the starter upper terminal with the Bracket, align and bore a hole on the plastic starter cover to accomodate the terminal plug and re-install it, then install the Terminal plug, Washer, and Protection cap on the bracket. That's all!
Hope this info is useful.
wncbmw
Post by wncbmw »
Thanks. That looks like a modification I can afford! :lol:
Vann - Lifer No. 295
What about the fat shiney negative terminal that screws into the cylinderhead?
Lean Angle
Weee donnneeeeed noooo steeengkeeeng negative terminal :lol:
My 02 didn't have the provision for it on the cylinder head, so I just use that big bolthead sticking out near the bottom of the engine. Works just fine :wink:
Of course, YMMV, blah blah blah, yadda yadda yadda... :)
username
Post by username »
pics?
Lean Angle
Sure, but how do I post them?
R4R&R
Donating Member #: 293
Post by R4R&R »
I added the same 'mod' to mine. Of course I haven't had a battery problem since (if that's what it takes, then it's worth it).
As for the ground (negative) - I can find many places to ground it to!
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
A good zero resistance jumper cable ground is important. You can't have the jumper cable's clamp sputtering thru a painted or fuzzy cad plated surface. The electronics don't like it (the sputtering/arcing). The BMW negative lug also has a clamp retention groove so it won't slip off and arc like crazy. I was under the impression that the same threaded hole (for the Negative Lug) or one like it nearby, also exists on our 2002 models. Anyone that's done this add-on know for sure?
Lean Angle
Sputtering/arcing, hmmm...is this what caused the ABS on the GS Adv to go south in Long Way Round when they welded the busted frame?
