I first used Mobil 1 brand which I believe is 75-90W. Shifting was still a bit stiff in cold weather. Switching to BMW's synthetic 75-140W and cold shifting was smooth. The difference between the two weights is really amazing.
I switched to Amzoil 75/140, I noticed a difference right away.( Although I never had any problems with the gearbox or shifting,) I could feel the difference, I think I am going to switch to the Amzoil for the engine also.
Den
gel9001 wrote:As per dealer recomendation, I've been running 75/90 since the beginning both in tranny and final drive.
When I stopped in my dealer/shop to pick up the 12k service "bits," I talked to one of the counter guys. (He'd been a service tech in the same shop for at least 5 years, and had JUST made BMW "Master Technician" then decided that he needed regular, 12 months a year income, to buy a house.) At any rate, HE gave me the grade/weight of synthetic oil to get for the drive/tranny. I figure if anyone has a clue which is best, he would.
Just curious, what would be the downside of using 75/140 vs 70/90 gear lube - other than of course voiding the priceless BMW warranty? It seems like the difference is trivial on the cold value and I wouldn't think that 140 weight could have anything but a beneficial effect when everything was fully warmed up.
challey wrote:Just curious, what would be the downside of using 75/140 vs 70/90 gear lube - other than of course voiding the priceless BMW warranty? It seems like the difference is trivial on the cold value and I wouldn't think that 140 weight could have anything but a beneficial effect when everything was fully warmed up.
No way using 75/140 gear oil would void the warranty. BMW has it's own highly recommended 75/140 synthetic gear oil.
