My GPS mounting solution
domekrome
Post by domekrome »
I use my Garmin 2610 on longer trips, and as of this spring I mount it with 2 different kits:
a) swivelling handlebar mounting kit from BMW, originally intended for the Navigator
b) Touratech aluminimum clamping bracket grafted onto 'a'
See photos here:
http://www.flickr.com/photos/kromedome/ ... 116443583/
Jason
Rockster Edition 80 #893
drevil
Post by drevil »
since the navigator is basically a 2610, could you use the regular garmin bike kit mount instead of the touratech to attach to the bmw handlebar mount? also though i wonder if the bmw mount would work for me since i have barback already installed....
domekrome
Post by domekrome »
drevil wrote:since the navigator is basically a 2610, could you use the regular garmin bike kit mount instead of the touratech to attach to the bmw handlebar mount? also though i wonder if the bmw mount would work for me since i have barback already installed....
I would imagine that you could use the Garmin bike kit, I didn't because it did not look like it would be that secure. I ride on a lot of rough, poorly maintained roads, not fire roads - just poorly maintained.
The BMW kit uses bolts that are the same length as the stock ones, just different heads, so I couldn't say if it would work with barbacks.
Jason
drevil
Post by drevil »
sounds like it migh not, since the barback replace the stock bolts with longer ones. you would probably need longer ones with the different heads.
i have the garmin mount and it is pretty secure( for plastic of course!). it even has a little torx key that locks it in place that you can carry on your keychain... plus it comes with the power cable and only costs about 10$ more than just the cable. worth a look IMO.
