help: i just melted plastic on my hot exhaust pipe
FM696969
Post by FM696969 »
my hot pipes touched my car cover as i pulled in the garage,
the car cover melted at the curve of the right exhaust.
how do i get the melted plastic from my exhaust pipe without scratching them?
any good chemicals?
NSBoarder
Post by NSBoarder »
Ouch!. I've done this before and it's a simple fix but takes some time. A couple of ways i've done it was using a micro torch and slowly burning and wiping off the plastic material. The easy way of doing it just warm up the bike till the pipes start getting hot, use Easy-Off oven cleaner and takes the stuff off like butter!. Be careful to use easy-off in a well ventilated area and also protect the engine area from the off spray by using a piece of cardboard box, also use goggles to protect your eyes!. good luck.
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
Bob
2002 Atlanta Blue
Lifetime Member #74
DJ Downunder
Post by DJ Downunder »
The pipes are stainless steel..not chrome...so you can get stuck into them with a metal pollish without any problems.
fallingpines
Post by fallingpines »
Are you sure that the R pipes are not chromed stainless? I started to polish my head pipes, but it looked like I was starting to cut though a plated layer and I backed off real quick. I have polished stainless pipes on my R60/2 and they are for sure solid stainless. I scuffed them once and they polished out realy nice. Also, after they get some use, they turn a nice golden color, not blue like the R does.
Kazushi
Post by Kazushi »
I use a hood over my R, I've had the inside stick to the front pipes many times.
I used liquid dish detergant while the pipes were still warm, plastic came right out...
leno
Post by leno »
fallingpines wrote:Are you sure that the R pipes are not chromed stainless? I started to polish my head pipes, but it looked like I was starting to cut though a plated layer and I backed off real quick. I have polished stainless pipes on my R60/2 and they are for sure solid stainless. I scuffed them once and they polished out realy nice. Also, after they get some use, they turn a nice golden color, not blue like the R does.
Mine are steel not chome so I've been quite happy with wet'n'dry to take off any hard stuck tarnish.
Boxer
Donating Member #: 2
Post by Boxer »
No hijack here. This just reminded me that I need the stuff that cleans off the gas stains on the tranny cover. Someone a while back mentioned some common household cleaning item that would do the trick, but now I can't find it.
Okay, back to the plastic on the header thread. Bummer. That's some ugly crap.
R4R&R
Donating Member #: 293
Post by R4R&R »
Boxer wrote:Someone a while back mentioned some common household cleaning item that would do the trick, but now I can't find it.
I'll bet it's the wonder product from downunder - Mr. Sheen!
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
DJ Downunder
No..not Mr Sheen...it's just a spray on polish cleaner...good for dirt and grime but not those stains.
Yes I'm sure...you can even get stuck into them with sandpaper or steel wool...then a metal polish.
It's a very complex thing this whole bluing thing...the s/s develops a type of skin and that's what you've found.
They can always be polished to a high chrome like shine...but it doesn't last.
