Garmin Quest GPS review
ErikU
Post by ErikU »
After getting tired of pulling over to get a map out, studying, then forgetting my directions a few minutes later, I finally decided to purchase a GPS for riding.
I am very familiar with GPS as an early adopter of a mapping unit over 10 years ago. I am also a pilot and have one in my plane and nearly consider it required equipment. I never wanted one for my car (I can read a map pretty well) and haven’t bothered to really look at units designed specifically for driving until recently. I honestly thought they were for dummies that couldn’t read a map. But… it’s a major pain to stop to pull out a map when you’re on a bike.
I wanted something small and inconspicuous, and something with a very low profile mount. Most of all, it had to be affordable. All my research led me to the Magellan Explorist 201 on the low end ($150 plus maps and mount totaled about $260) and the Garmin Quest ($330 plus $15 mount) on the high end. I knew I would need detailed maps which was included in the Garmin, but extra in the Magellan. The Garmin has a color display and is designed specifically for driving. The Magellan is B&W and is more of an “outdoor” unit. I ordered both from Amazon.com
For driving, the Garmin Quest is the hands down winner. I had no idea how well they designed a unit specifically for driving. It comes with a map DVD and mapping application for your PC. You can connect your GPS to the PC (included cable) and send the detailed map region to the unit. I selected all of WA, OR, ID MT, and most of northern CA. There was still plenty of space left over. The Garmin Quest II is the same unit, but with more memory for maps, which for me, I don’t need. The mapping application also makes it easy to build pre-defined routes and waypoints. I used my Destination Highways WA book to make routes for several rides I want to make this summer. You can also make the routes on the GPS directly, but it’s easier to do it on your PC and load it to the GPS.
I was worried about mounting on my R1150R, and also worried about readability in direct sunlight. I decided to give the $15 bicycle handlebar mount a shot before I spent the big bucks on something fancy. It works very well. It was a very tight fit, and I had to loosen the handlebar mounts to get it to slide in, but that was just a one-time thing. I am very pleased with how it works. It doesn’t block any of the instruments or lights, is very low profile and is flat up against the bars, pops on and off in less than a second, looks good with a finish that is close to the roadster dash, and seems secure. The angle it’s mounted at also keeps all of the glare off the screen.
The second picture shows the mount on the bars with the GPS removed. The GPS is smaller than it looks in the picture. It is compact enough to go in your pocket when you get off your bike. I am using the built in battery that is supposed to be good for 18hrs. I have found that I can read it just fine during the day with the backlight turned off, so in that configuration it should last even longer. They do make a motorcycle kit for external power, and a audio cable to go to your intercom if you have one, to hear the verbal directions (“turn left in 200ft, then keep right” sort of thing). If you don’t have the motorcycle kit it will beep at you for upcoming turns, and you can just barely hear it over the engine.
When turned on, the GPS simply plots your location on a map, including your current speed, time, elevation and direction. Across the top it will tell you what street you are on, and what cross-street is coming up at all times (“Traveling E. on Jefferson, 12th Ave next”, on the freeway it tells you what exit is coming up “Exit 122 – 4th Ave S. in next on Right”). It also tells you your max speed, average speed, etc. Very handy.
In navigation mode it computes the best course to get from where you are to anywhere you want to go and includes excellent prompting for upcoming turns, exits, etc. It also seems accurate at estimating your arrival time. The database includes almost every business and you can search for just certain things like gas stations, banks, Mexican food, etc. You can also search by business name if you know it. It includes business phone numbers so you can call to see if they are open, then it will compute the best route for you to get there. Additionally, you can tell it to avoid freeways, toll roads, unpaved roads etc. If you would rather plot your own course, you can do that, then just follow the guidance to get there. One button push and it will compute your best route home! When I pull up to my house it says “Arriving home, on left”. Pretty cool, and very accurate!
The box also includes a suction cup mount for your car, and a cigarette lighter cord for power that includes a little speaker with volume for the voice guides.
All in all, I am thoroughly impressed. This is one very cool little box. The only thing I could warn you of is that the screen may bit a bit small if you don’t have good eyesight. It’s fine for me.
'02 R1150R
TonyT607
Donating Member #: 156
Post by TonyT607 »
Erik, great write up. I bought my Quest in November for $299 from Costco online. I'm very happy with it so far. The mapping software is pretty good. I use the unit in my cars and on the bike. I bought the Garmin M/C mount (with power and audio) and it works well.
The XM Roady and Quest are on a custom mount kit from Gadget Guy. The XM is mounted to the Gadget Guy Base Plate with 3M Dual Lock. The V1 and my EZ Pass toll tag are mounted on the reservoir caps, also with 3M "Dual Lock". That stuff is amazing, like Velcro, but with ZERO movement. It's almost like your devices are bolted on, but you can yank them off in a jiffy.
Tony
Lifetime #156
2013 K1600GT
vinman
Post by vinman »
So, have you guys used your Quest for very long trips? Or in areas your not familiar with at all?
I bought my Quest in Dec 2004. Overall I think its a good unit. BUT, I do take issue with acouple things. The biggest problem I have with the unit, or I shoudl say the software, is that it usually uses a route (road) name instead of a route number when providing directions. Now I've traveled about 10,000 miles with my Quest so far in many states between MD and CA and except for 2 or 3 instances I have always seen route signs using a number and no name. The Mapsource software does not provide both, only a route name. This sometimes makes things confusing since you're looking for a road sign with a name and not a number.
The other big issue is that the directions sometimes do not update fast enough. This is a problem when you have to make a couple or more turns in quick succession. So, it helps to read and memorize the directions before hand because if you have to make a turn within a couple hundred feet of the last turn chances are you will miss it. Somehow the quest seems to recognize this relatively quickly and then starts recalculating to tell me to make a u-turn or make me go around teh block.
Its most definetly not a flawless unit. I wish they were cheaper when I bought mine. I paid just under $600.
A big plus is that the battery will last about 20 hours if you turn off the back light or only have teh back light when it signals you to turn. The type of screen they use doesn't need any back light when its in direct sunlight. Its very clear and easy to see in sunlight.
"Be a man and face the fire. Make something ugly into something beautiful." Unknown taxi driver.
chris
Post by chris »
I use TomTom mobile on my SPV C500 phone in my pocket and just listen to verbal directions in the headset. Works well but I was looking at the Quest 2 in the BMW dealer at the weekend. Couldn't see it working though so wondered if it has the 3D route display that TomTom has?
Chris
2011 G650GS
Photos
12bar1
Post by 12bar1 »
I have been using the Garmin products for about 6 years. My job has me traveling to unfamiliar places all the time and I would be MIA somewhere if not for my GPS. I just upgraded from the V+ to the 276C and all I can say is this thing rocks. I can see the screen without my glasses, it has lots of memory and recalculates almost instantly when I ignore or miss a turn.
Yer wanted by the police and my wife thinks your dead.
Post by Doug »
I love garmin stuff too. The Nuvi 350 I bought recently is the best I've owned so far. Lots of goodies, and very well done interface.
ErikU
Post by ErikU »
The Quest doesn't do a 3D display, which I don't like anyway.
I haven't had any trouble with two turns in a row without enough warning. I always glance at the display when it tells me to turn so I know exactly what to expect.
I have had no trouble at all with route names vs numbers, and have taken it on several trips to places I didn't know at all. However, I think it's different on the west coast. I have noticed when driving around the NE that the route name/number thing is confusing. The few instances I have run into of that here have been listed both with a highway number and name if applicable.
'02 R1150R
R4R&R
Donating Member #: 293
Post by R4R&R »
I'm happy with my Quest and what I spent for it (I think I paid just under $400 about a year ago). I bought the RAM mount/cradle for it so it is powered by the bike and charges the batteries.
I've seen the 276c in a bike and really like it - that will probably be my next GPS, but it will be a while. While GPS units are nice to have they can't replace a map when looking at a full day of riding and routing.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
