I just rode with my new Moto-Techniques Bar-Backs!
This was the best $40 I've spent so far. I bought the Modified 1" rise and 1 and 5/8" setback kit. The quality is great, the installation is simple, and the price is right. The new position of the bars is right where I wanted them. I rode around for a few hours today and was much more comfortable. I would highly recommend this product. They don't look as good as the Verholen ones, but they cost about a sixth of the money.
Enjoy the bar backs! Quite a difference for such a small ergonomic change, isn't it?
I went to the Wunderlich Touring Wellness bars from the MotoTechniques and wholeheartedly recommend them. If you try them, write back here for tips on the removal/installation.
#429 (in for life)
'06 Silver R1200RT
'04 Titan Silver R50R (3/05-9/10 was a good friend - RIP)
'06 Silver R1200RT
What is the big difference? Are they wider than factory bars? What is your body position now compared to just the barbacks? Did all the cables and wires clear? Thanks, Troybimrluvr wrote:Enjoy the bar backs! Quite a difference for such a small ergonomic change, isn't it?
They are further back, a little bit taller. Wider so you have beter leverage for quick steering. I sit more upright than I did with the barbacks. They're neater looking.
I did not have to change any cables, etc., but I did extremely slight rerouting to allow for more play in the lines and eliminate sharper bends on brake lines, etc.
Some pics, might help...
http://mcpatents.com/Family/R1150Rpage.html
#429 (in for life)
'06 Silver R1200RT
'06 Silver R1200RT
Your bike looks great! I'll most likely take that route later in the summer. I've got lowering pegs on the way from another member for my next project. I really like the bar-backs, but at the end of the day they don't look factory. I guess that kind of bugs me.bimrluvr wrote:They are further back, a little bit taller. Wider so you have beter leverage for quick steering. I sit more upright than I did with the barbacks. They're neater looking.
Bimrluvr: Do the Wunderlich bars come with decent installation instructions? Any problems with changing over the heated grips? It looks like the bars are chrome rather than a dull brushed silver like the original. Correct? I was going to try the bar backs, but you've convinced me to go ahead with the Wunderlich bars.
Thanks, Al
Thanks, Al
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
Yes, the bars are chrome, nicely done.
There are no installation instructions to speak of. I used my Clymer's manual as a guide to figure most of it out.
Basically the steps are:
[1] remove gas tank and undo grip heaters from their Molex connector. That will let you pull the wire back through the handlebars after everything else has been loosened.
[2] Next remove each and every screw holding the control housings together. There is one screw hidden by the mirror shaft and there are some that are visible only from below. It all pops apart, piece by piece until you can access the main bolt that holds the control to the bar.
[3] Remove handle bar end weights.
[4] peel back rubber grips enough to see if there is a screw holding the grip in place (the left one has 3 such screws) and remove the grips.
[5] remove controls and take off old bars.
[6] Do steps 5, 4 3 2 and 1 to reassemble.
The one major mistake that cost me later was trying to remove the grips without first removing the tank to disconnect the heater plugs.
Another tip would be to undo all cable ties for the controls and drop the headlight assembly so you can easily reroute the cables without losing any play.
It was a fun project that I can now do in a third to half the time it first took me.
#429 (in for life)
'06 Silver R1200RT
'06 Silver R1200RT
Funny how people's riding preferences are so different. I want shorter and more forward bars, like a R90S. I believe Wunderlich makes a set which is on my very long list of things to add to the bike.
When I first got the Roadster, I thought the stock bars were ape hangers!
Of course, I spent many a year with my old R100RS clipons and even after I changed out to KRS bars, I still very much had a forward position, which I would like to get back.
Vann - Lifer No. 295
Sure thing, Al.
Vann, the difference could just be that I am 5' 3" with inseam and arm lengths to match. The difference between a very forward reach and where the touring bars put, is the difference between tippytoeing all the time and being able to put my feet (or one at least) flat on the ground at a moments notice. Also, steering is less complicated if I don't have to lean forward, putting all my upper body weight on my forearms/wrists, which necessarily keeps my arms stiff out and hard to readjust for giving properly subtle steering inputs.
#429 (in for life)
'06 Silver R1200RT
'06 Silver R1200RT
- RiftonRoadster
ok- I'm gonna jump in on this wunderlich touring bar thing.
I already have the longer barbacks. I've done the valves and TB's to keep the vibes at a minimum and I'm looking at decreasing the vibrations even further. I'm going to try removing the barbacks to see if that works as I've had them on since I got the bike.
Do the wunderlich bars reduced the vibes. The Ricky bars claim to do so but right now the price is a little steep for me.
2002 Red R1150R - "Katarina"
1991 Honda Nighthawk 750 - Sweet Ride
It might reduce the sensation of vibes only because you're putting far less pressure on your forearms/wrists/hands, but I won't swear to it. The bars are a little heavier so that may contribute to quieting the vibes.
I have noticed that my Held Fresh riding gloves seems better at reducing vibes than any other "light" gloves I've tried.
#429 (in for life)
'06 Silver R1200RT
'06 Silver R1200RT
