I Need The Shocking Truth About Shocks
The MAX BMW parts fiche lists two different parts numbers and prices for the front shock.
31427650047-costing $368
31427689856-costing $250
Does anyone know what the difference is on these two standard shocks?
Also, can the rear BMW shock be rebuilt?
The rear BMW adjustable shock is...If I remember?...around $650
Works Performance shocks are right at $1000 for both
Ohlins come in at about $150 more. Both of these can be rebuilt apparently.
beemerphile
beemer-biker
Pat
The factory shocks can in fact be 'converted' into "rebuildable"....... don't waste your money though, use it instead to apply toward better shocks.
Works Performance makes a very decent product, and you can deal with them over the phone. Kind of a personal touch. After you log thousands of miles on 'em, score the moving parts with particulate you never washed away, or exhaust them with tons-o-camping gear over rough roads, Works can rebuild them. Nice.
Ohlins has a reputation that precedes them..... racing. Buy them, and you might find them rough or too stiff. Ohlins will swap out the spring one time at no additional charge. They are a quality shock that you can take to a suspension specialist to have re-valved for YOUR particular needs/bike. It's quality stuff that a trained mechanic can tailor for you, be it for monthly Track Days or annual Iron Butt adventure.
Never would it be more true when talking shocks, that to say that you get what you pay for. You can buy a cheap fix for 'cheap', you can buy shocks good enough for a season or two before you sell the bike, or you can spend a little more money in keeping with the craftsmanship of the rest of your bike. Are you cheap, just passing through, or true to the spirit of a superb road machine? Your shocks will speak volumes about you.
Member #31
ferroknight
Brought stock rear shock to Jim Lindemann in Campbell, CA. I didn't like the soft-ish feel and low preload/ride height, so he revalved and installed a 1300 lb spring and converted to nitrogen charged with Schrader valve on shock body.
Then I replaced rubber line from preload reservoir to shock body with steel braided hose. This was a daunting task because the BMW banjo fittings are 8mm, while everyone else is 10 mm. I had Jay at American Streetrod custom weld two 8mm x #4 using my standard fittings.
Since the reservoir is so close to the cat, the hose is sheathed in high-temp wrap.
John Carabillo
Beemeridian
765
2015 Honda PCX150
2015 Honda PCX150
ferroknight
