What can the System Bags handle
I'm heading out in a few minutes for my first long extended ride (5 days). The manual says the you can't exceed 80mph with the bags on. I just want to know if anyone has ever had trouble going over 80 with bags loaded?
k
k
MikeCam
- Centurion Moderator!
No Problem
Two things.
1. You might feel a slight wobble/weave/shimmy at higher speeds as the bags catch air and change tghe straight line performance. Lightly grip the bars and it's no big deal.
2. Weight in the bags above 22 Kg can cause the mounts to stress at higher speeds. Again, not a problem, just a stressor.
Have too much fun!
Have too much fun!
Kristi,
Good luck on your trip. I made a trek to Ohio and back last year with loaded system cases. I have hit some pretty high speeds with them on and have never had an issue. I think you will feel it if it gets too fast for the weight you are carrying. Make sure to pack them as evenly as possible. Have a blast!
Julia.
Julia.
I've had mine over 100mph without any problem (not for extended periods). I've also had brake drums in them (again, for a short period) from my GMC - I would guess they weighed around 30 pounds each. They really made the bike balance well when coming to a stop!
As for packing the bags for a multiple day trip, I wouldn't worry about it unless you're taking bricks. Try to keep the bags balanced in weight and have fun.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
System cases
Like DJ, I've done near 200km/hr with the system cases and top-box on my RT with no noticeable effect on the handling.
At the risk of dobbing myself in for some speeding tickets............
I have regularly run my bike, fully loaded, well into the 100 mph zone. On my recent trip, with a huge load, the bike ran fine up to 180 km/hr. See the trip folders for pics of the load I was carrying.
I also had an extended spell at 160 km/hr plus on the trip as the Northern Territory has no max speed limits.
My only concession to full bags and a decent load was to crank the suspension up full hard, and back everything off one turn.
These bikes a very stable at speed, and I have never experienced a wobble or shake at any speed on any sort of road. That has included some pretty average blacktop.
Load the cases up, go whatever speed you are happy with, and be confident that it won't be the reason you come unstuck.
And please don't flame me for inciting unsafe riding practices that are contrary to BMW and GIVI load limitations and speed ratings.
one thing to watch
Kristi -
I always figured the speed limits on panniers was intended to take headwinds into account. Say you're doing 100mph and have a 50mph headwind your effective speed goes up to 150mph.... I've see 120mph with fully loaded panniers (without headwind) and have had no issues.
A well fitted set of pannier rails is important to ensure the boxes don't work free. Mine are 4 years old, used every day and rock solid.
Tom
http://members.optusnet.com.au/~lonergans/
Tom
scottybooj
I did 110 mph on my bike with loaded bags. The bike seemed to be on rails, and perhaps had more throttle to go. Since I was on I-95 in Maryland, I thought it best not to go to jail.
I read the 80 mph rule later in my manual. oops.
Perhaps they meant EMPTY bags?
Spilferderber
scottybooj
- munchmeister
