Oil Consumption
- RobMason
Oil Consumption
I have an '04 R 1150 R with about 220 miles on it. (I bought it late last year and am just getting around to getting some mileage on it after back surgery in the winter), and it seems to go through oil like juice thru a goose, I am doing rides that vary the RPM (sometimes up to 4000 RPM, but after a 40 mile outing the window is half full (or empty), is this normal??
Rob
Rob
'04 Titan Silver R 1150 R
peterbulgar
Probably. Oil consumption is often high on these bikes when they are new, tapering off to an acceptable level when they break in - somewhere between 1000 and 15,000 miles.
You want the oil to be at the midpoint of the window and not much higher (yes, I know that most dealers, as part of a normal service, will put in a full four quarts, which will leave the oil level at the very top of the window). I don't add oil until the level is near the bottom of the window, and then just enough (4-6 oz.) to bring the level to the midpoint or slightly above.
Many people on this forum recommend ignoring the detailed break-in instructions in the owner's manual and instead pursuing a much more aggressive break-in regimen of "ride it like you stole it". The idea is that the engines will not break-in correctly unless they are subjected to high rpms and high loads early in their lives. (These same people by the way always seem quick to post an admonition to look in the manual whenever anyone asks a question about any other topic that is covered in the owner's manual.)
My own bike with 35k miles goes through about a quart every 2500 miles - less than it did when the bike was new. Many people who broke in their bikes by the manual report negligible consumption between oil changes, as do many people who were bouncing off the rev-limiter from day one. Of those whose bikes use oil to some extent, and I count myself among them, some broke them in conservatively by the book, and some didn't. Whether an individual bike continues to consume oil seems to depend more on chance than any particular break-in procedure, which, if these were Japanese bikes, would raise questions about design and quality control. Since these are not soulless Japanese appliances, we attribute these quirks to character.
Peter '73 R75/5, '04 R1150RA
RideandDrive
These are engines and the oil is used to lubricate. A quart every 3K is not unusual. I like to keep the level mid window and add a few ounces when it hits the bottom of the window. I use the ride it, on the side stand @ 5 minutes, and then center stand method to check the oil level, for consistency.
Evil beware, we have waffles.
'03 r1150 - the beast
'11 r1200 - Hooligan
#564
#564
peterbulgar
First this is an air cooled motor and as such it has a temperature gradient or difference between the front and the rear of the engine. Now if you understand this you will also understand that uneven heat is not conducive to maintaining a perfectly round cylinder bore. This is not a critical problem with the Japanese bikes because they are water cooled and have the ability to maintain a near constant coolant temperature in the cylinder area.
Second the BMW cylinders are coated by a process called Alusil, the other variant is Nikasil, which are extremely hard, read wear resistant surface coatings to increase longevity.
Now if we understand that the break-in period is the accomodating of the piston rings to the surface of the cylinder so as to realize a "honing" or polishing effect to minimize gasses and oil seeping between the rings and the cylinder wall then we can begin to understand what is taking place.
On one side you have a hard cylinder surface to wear in, on the other hand you also have a cylinder that is not perfectly round because of temperature gradients and you need the rings to break-in to the cylinder surface to minimize oil consumption.....now isn't that a dilema.
The solution here, for a quick accomodation is to subject the engine to as many load cycles as possible where the temperatures and engine components tend to "mold" to each other.
This agressive break-in does not preclude running the engine without the proper amount of oil, nor before the oil and the engine have reached NOT (normal operating temperature) or even before the first oil change or 600 miles.
However it does mean that once normal operating temperature is attained you can run the engine rpm up and down, open and close the throttle to get the engine working hard.......taching the motor a few times and in essence riding the bike "like you stole it" for lack of better words.
Irregardless of what you choose to do, the outcome is pretty much known to those that frequent this forum....you can have your oil consumption down to normal levels, as mentioned earlier in this post, or continue to keep adding oil until the engine is broken-in.
Some people, yours truly included, had stopped using oil by the time 5500 miles rolled around, there are people in this forum that have 20K to 30K miles and they still burn oil and their engines will probably never break-in.
For a little more ammunition, look up CYCLEROB's pictures of his decarbonization at 47K miles, his bike was well broken in, however, look closely at the pictures of the cylinders and you will see still the crosshatch markings of the factory honing process..... now that says something about minimal wear..............
I'm going to take exception to you quote, since I fail to see what is the point you are trying to make. On the other hand, I count myself in that grouping that advocates the agressive break-in process, however, I do understand and identify with the methodology of why this has to happen and if you will indulge me I will explain.Many people on this forum recommend ignoring the detailed break-in instructions in the owner's manual and instead pursuing a much more aggressive break-in regimen of "ride it like you stole it". The idea is that the engines will not break-in correctly unless they are subjected to high rpms and high loads early in their lives. (These same people by the way always seem quick to post an admonition to look in the manual whenever anyone asks a question about any other topic that is covered in the owner's manual.)
peterbulgar
My point is that many people on this forum recommend a break-in procedure that contradicts what is stated in the manual. You provide well thought out reasons why this may be a good idea, but my statement is still true. It has also seemed to me that some of the same people who recommend ignoring the official break-in procedure also point to the manual as the official word for every other procedure that comes into question. I find that to be ironic, which is why I mentioned it - anything to liven up an oil thread.
From the responses to this and any number of other oil consumption and break-in threads we can say for a fact that some bikes use oil and some do not, and that some people broke in their engines by the book and some did not. For whatever reason BMW prescribes a rather conservative break-in procedure the end result of which may be a bike that consumes a certain amount of oil for the rest of its life. Or not. Then again BMW also considers oil consumtion of 1200km/litre (I think that is right) to be acceptable.
FWIW my air-cooled 650 Yamaha twin did not use an appreciable amount of oil and neither did my air-cooled 750 Honda four or my air-cooled 750 BMW. My BMW R90/6 (air-cooled, 900cc) did use oil at the rate of about a half-quart every 2500 miles.
peterbulgar
Please consider a couple of very important things regarding the BMW boxer engines. It is very easy to get oil into the cylinder being that it is in the horizontal plane.......most of the other bikes, their cylinders are at a steep angle to the vertical and it is much more difficult get the oil up there since it has to fight gravity.
The other one is that if you fill the sump to the top of the bullseye and place your bike on the side stand, you will notice that the left cylinder will burn some oil the moment you start up the bike, that will also add to your oil consumption.
Basically the boxer design is much more prone to having oil in close contact with the cylinders, therefore making the oil control ring job far more critical than for most other bikes.......so therefore one can expect slightly more consumption.
I don't even bother w/ the sight glass while on the centerstand anymore.
I'm doing what a bunch of knowledgeable riders on the ST forum do....
At my last oil change, I put in a measured 3.5 qts of M1 15w.
I check my oil on the side stand a few minutes after a ride, or anytime during a ride actually. If I see oil at least 3/4 up the window, I'm good to go.
In the 2000mi since my last change at 14000mi, I've put in 6oz to keep the level consistent....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
- geothepencil
We had 2 identical new 02 R1150Rs and one used oil and one didn't, both broken in the same way. The one with oil usage is tapering down but not until about 15000 miles and it uses less when run for long trips. I think its just luck that determines how much oil one will use or not use, but I am happy that ours doesn't consume the quart per thousand amount that some quote as routine for them. We are in the quart per 3K range with ours.peterbulgar wrote:boxermania
geo
I always follow the owner's manual when breaking-in an engine. Engines can be broken-in many different ways. However, I believe the company who designed and buillt an engine knows best. And besides, if an engine fails due to improper break-in, who's going to honor your warranty?
'96 BMW R1100R
'05 HD Electra Glide Ultra Classic
- Arbreacames
Al,boxermania wrote: Irregardless of what you choose to do, the outcome is pretty much known to those that frequent this forum....you can have your oil consumption down to normal levels, as mentioned earlier in this post, or continue to keep adding oil until the engine is broken-in.
The point that Peter is making is that there is no clear proof that a by-the-book run-in is more or less likely to cause oil consumption. In fact, there are plenty of owners who have run-in two or more bikes the same way and have gotten different consumptions.
Secondly, I am not convinced that oil consumption always goes down with miles. I am at 45,000 and consumption has been irritatingly steady for 15,000 miles at 0.5 qt/1000 mi on Mobil 1 15W50.
Thirdly, not all the oil leaks happen between the ring and the cylinder wall. Some of it could be leaking by the ring split, especially if the splits in all rings happen to be aligned.
Finally, I have seen no proof that the oil gets into the combustion chamber by the rings. I suspect that the valve seals may have something to do with the problems. If that were the case, no run-in would make a bit of difference.
Carlos D.
Ed K
Guys,
IMHO there are so many rider style factors that influence oil consumption... that its not possible to conclusively state anything on the internet about a particular bike/rider.
I work the heck out of my R1150R virtually each and every ride, with extended high revs while mountain strafing, and it continues to run like a champ.
The compression is at its very upper most limit after 13000 miles (I had it checked at the shop), but still consumes significant oil.
On the other hand, if I am easier on it, not much oil is consumed.
Don't worry about it, and enjoy the ride!
(Just keep one eye on that site glass.)
Ed K
07 K1200S
Lifetime Member
07 K1200S
Lifetime Member
I bought my R1150R new and have had it for just less than two years. I ride weekends only ie no commuting. I have just over 30,000km on the bike and keep good records for fuel, oil and tyre life. I have used exactly 6 litres of oil in those 30,000km ie average consumption 1litre per 5000km.
For breakin I use the same technique as I used many years ago with racing car engines after a rebuild. Gas pressure is important in bedding the rings and so varing throttle openings with reasonable revs and a bit of a load is important. No load and high revs is not good. I didn't flog the bike during the initial breakin and then applied progressivesl more revs and load during the rides.
I don't have a problem with it using a bit of oil as horizontally opposed engines (as has already been stated on this thread) will, by design, have more difficulty in controlling the oil on the cylinder walls. It is even more difficult to control the oil on the walls when oil is being squirted around for cooling purposes as well.
I am using a bit less oil now than when I had 20,000km on the bike.
BoxerFan
'04 R1150R
Member #588
'04 R1150R
Member #588
I currently have 7000 miles on my bike and it burns a quart every 1000 miles. Bottom line, the cylinderwalls are slick and hard as diamonds, it takes a while for everything to seat. Run your bike as hard as you want, its a BMW for pete's sake. That's all that really needs to be said. It can, most likely take any punishment you have to dish out and then some.
I don't imagine my oil consumption tapering off completely until about 20,000 miles. Run it; never below 3,000 RPMS, never above 6800 RPMS. Stay in the power band and enjoy. Look at the bright side, you're not leaking it like some brands, you're just burning it.
Enjoy your scoot.
Enjoy your scoot.
- dwayne
I know you where expecting someone to pipe up, but... Most Jap bikes I have owned were air cooled. My Suzuki LC 1500 had a similar cooling methodology as the Boxer, Air / Oil cooled. My Yamaha was only air cooled.... This is not a critical problem with the Japanese bikes because they are water cooled
...That isn't a real word. Major Pet Peeve. It's "regardless". Period.Irregardless
'05 R 1150 R Dark Ferro, with blacked out motor Member # 507
- dwayne
irregardless of the fact that I made a spelling mistake, it is irrespective of the point.rdsmith3 wrote:were? (sorry, could not resist, given comment below)dwayne wrote: I know you where expecting someone to pipe up, but...![]()
or "irrespective"dwayne wrote:...That isn't a real word. Major Pet Peeve. It's "regardless". Period.Irregardless
Hey Dwayne, how you getting along with your oil lately? I checked mine last week, 3 days on the bounce it was low. Put a thimble full in and it went off the top of the glass. I've given up worrying about it now, it'll do whatever it wants and there's bugger all I can do about it!
On a different note I'm test riding a 1200 sat am...no intention of buying but I couldn't resist the offer!
