clocks going wrong
geordie50r
clocks going wrong
Post by geordie50r »
Hi,
Has anyone had problems with the the clock? Mine is loosing time quite badly. Can you replace just the clock or is it part of the whole speedo / tacho setup?
On the positive side I had another hour or so on the bike.
Comments appreciated,
Steve
ne england
Post by CycleRob »
The clock is seperate and easy to replace -BUT- it is horrendously expensive.
I'd take it apart, check all the connections and look at the fuse's blade terminal grasping strength by it's spring terminals. Moisture and vibration can take their toll.
Your plan B should be get a self powered half inch LCD stick-on clock, about $8 from Radio Shack, and put an automotive temperature gage in place of the clock.
Beemeridian
Donating Member #: 477
Post by Beemeridian »
645
2015 Honda PCX150
scottybooj
Post by scottybooj »
oh, you guys didn't realize that as the euro and the $dollar get further apart in value, the clock gets more and more inaccurate?
you must have missed that service bulletin.
:wink:
Scott
Black '50R
Long Island, NY
baltm604
Post by baltm604 »
Has anyone tried these guys to get a clock or gauge repaired?
http://www.speedometerplus.com/
R4R&R
Donating Member #: 293
Post by R4R&R »
My clock has always run a little fast and I don't mind, it keeps me on time. :wink:
Since we reset our clocks every six months for daylight savings, it doesn't get too far off. I think it's currently about 12 minutes fast.
How come there was never a 'metric' measurement for time?
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
machew01
Donating Member #: 345
Post by machew01 »
Yes, there is a metric measure of time. I check my watch every 10 minutes.
mac
Beemeridian
564
2015 Honda PCX150
R4R&R
Post by R4R&R »
Beemeridian wrote:Actually, time is measured in metric, which associates properties to a system of coordinates. If the earth were divided into 24 segments at the equator, the first segment would return to it's starting point relative to the sun at almost exactly the same time each day, (well almost, the solar day is 3 minutes and 56 seconds longer than the sidereal day). Thus, timekeeping took advantage of this convenience to divide the 24 into measurable and usable units.
Dave
Why 24? Why not 30, or maybe 10, or even 100? Take meters, broken into subs of 10's or 100's. We have hours, minutes, and seconds that don't easily add up. 60 seconds, 60 minutes, oh we'll take 24 hours. How about 60 hour days? Then 600 hour weeks?
All of these numbers are making me hungry. I'm getting something to eat. 8)
DSKYZD
Donating Member #: 187
Post by DSKYZD »
You could replace the clock on the bike with a binary clock:
10:48:36
JOURNEY JUNKIE #187
Gordium7
Donating Member #: 566
Post by Gordium7 »
Where is the psuedo-binary clock available from? Sharper Image or some such?
I want for my office desk!
I am such a nerd...
2005 R1150R -- Granite Grey Metallic
Lifetime Member #566
touchton
Post by touchton »
Gordium7 wrote:Where is the psuedo-binary clock available from?
If you like the binary clock, it, and many other geek toys, is available here: http://www.thinkgeek.com/
Post by CycleRob »
Cool clock, but it takes too much thinking to get a reading, even for a closet geek like me. It nay be easy to learn by watching the seconds tick away and note what lites are lit.
For the people scratching their heads, the binary system is based on the powers of 2. In the case of the clock, only numbers up to 9 are needed for a sequential HH:MM display.
The 1, 2, 4, 8 sequence goes vertical upwards on the clock. When the bottom 3 lites are lit in one vertical "row", you add their values: 1 + 2 + 4 = 7 for that digit. Nothing lit is zero. The blue dot clock below also shows 10:48:36 (AM) and it goes for $23. On the website I had to search "Binary Clock" to find it quick.
geordie50r
ta for the help
Thanks for the words of wisdom regarding my dodgy clock. I think I,ll take my time in deciding my next step.....
steve
Ed K
Post by Ed K »
Steve,
My clock also went kaput... well almost kaput...
It was starting to lose hours of time... which did make my ride a bit more enjoyable at first... but then also eventually lead to other problems. :roll:
I just had it replaced under warranty last Friday.
Ed K
07 K1200S
Lifetime Member
Donating Member #: 312
Post by boxermania »
I have use the speedometerplus that balt604 made mention of. Not on the BMW clocks specifically, but on Porsche 911 vintage clocks. They are timely and reasonable.......haven't used them lately. 8)
Dr. Strangelove
Post by Dr. Strangelove »
>>Actually, time is measured in metric, which associates properties to a system of coordinates.<<
actually(IIRC), the twelve (duodeca-something) systems comes from the ancient Babylonians who used a base twelve system in their math.
No probs with my clock (yet).
'09 Schwarze Blanche DuBois
iowabeakster
Post by iowabeakster »
i love this bike's clock. Seriously i think it is one of the best little features about the R. i would be so sad if it screwed up. For two years now I have never reset it, and it has always been dead on accurate.
geordie50r
What were the 'other problems'?
steve
NoRRmad
Donating Member #: 388
Post by NoRRmad »
Since we're talking about clocks, I do have a little problem with mine. There's a button on the back you press to advance the time. I can't see the button, 'cause I have a smoke-colored sports screen, but I can feel it OK. When I press the button (hard to do with the screen in place,) the time advances two minutes. If I'm going from one time zone to another, I have to press the button thirty times! Once, I pressed the button and the time began to unwind at a fair clip, and continued until released -- which I think, is the way it's supposed to work. But, it never happened again. Is there some secret to re-setting the time?
