It died then... came back to life!
geordie50r
Post by geordie50r »
Here is the story,
Out on Northumberlands finest road the A696 this afternoon. Gave the bike very good thrashing, trying to keep up with pals on GS1200's and a K1200r.
Over took a VFR800 south of Otterburn Village and the bike died. Dead a parrot. Pulled over to the side of the road. When I turned the ignition key the sound was not the normal 2/3 second 'wurring' (whatever that is) but a more continuous buzzing noise. (didnt sound good)
The bike was obviously not going to start. Had a check to see any obvious problems, plenty of fuel, no leaks, etc. Got on the phone and called the rescue service. Four hours later Iam home. Had a bite to eat, walked the dog, went into the garage. Turned the key, got my regular 'wurring' noise, pressed the button and ..... yes your right it came back to life, started up, sweet as a nut!
So, whats that all about then?
Has the 50r healed its self? perhaps, it didnt like the thrashing it got on the A696? Do I ride it as if nothing happened?
Can anyone solve this mystery? Had a similar 'back to life experience?
Cheers - Steve
Post by DJ Downunder »
Just a guess but I think it's a fuel thing..how full was the tank when it did it...and just how does the fuel get from one side of the tank to the other?
What year is the bike?..has the fuel filter ever been changed?..I wouldn't worry too much about it..unless it continues to do it.
leno
Post by leno »
check your wiring around the headstock. Mine was fine unless I wanted to turn right. But it did not happen every time and it took me ages to work out what it was.
Donating Member #: 2
Do you have ABS? If not the whirring sound at "key on" is the fuel pump coming on. If that went away and was replaced by a different sound, I'd suspect fuel pump problems. Either a connection to it is coming loose, or it's going bad and will work some times but goes off under certain conditions.
Mind you I'm no mechanic so that's just my take on it from what you're saying. Check wiring connections first and go from there.
geordie50r
Went to work today on the bike, thought i would take a chance. No problems apart from things not sounding correct in the 'wurring' dept.
This is a non abs 2001 R
Had a chat with a mate who knows about these things, he reckons its the fuel pump.
steve
Sounds like your friend might be right..have you had the bike from new?..how many miles or kilometers are on it ?
I've heard that running out of fuel can damage the fuel pump if it runs dry..maybe that's whats happened..let us know how you go with it.
Based on your comments I go for the fuel pump.......because it sounded different while hot and then went back to normal when cold. Change the filter too..... 8)
geordie50r
Thanks for that Boxermania. Hope you are correct! Ive just ordered a fuel pump, plus the fuel filter (£50 second hand or £200+ for a new one) Might have a go at doing the job myself. Is it a difficult job? I can do the oil changes, and even managed to fit some new brake hoses. Do I need a new challenge?
cheers
steve
chris
Post by chris »
I had mine replaced because the mounting plate had buckled and fuel was leaking onto the right head. The dealer charged me £80 labour. From what I saw it doesn't look to be a difficult job, tricky re-assembly with all the lines etc. but with a little patience you should be OK. You might need a new o-ring to remount the backing plate as well, only a few quid but they tend to grow over time when exposed to fuel and don't go back properly.
Chris
2011 G650GS
Photos
geordie50r
cheers Chris, I think I will pop over to hexham on friday. Theres a garage that does all bmw stuff, one of the mechanics is a dab hand with bikes too. motoworks did the pump for £50, secondhand, I remembered to get the o ring too.
steve
