Top-up
\\Mike_Lea//
Top-up
Post by \\Mike_Lea// »
Checked the oil level at the weekend...
Went out for 0.5hr or so to get upto temp. then back home. Stood for 10mins, then upright and checked the level.
Having done around 1500 from the last service, I have noticed that the level seems to have gone down a bit. Does that sound about right?
Having only had the Rock (my first BM') for less than six months, I'm not totally familiar with what's the norm...
Castrol GP?? is what I need as I recall... Halfords (UK) stock it don't they?
M :)
Shine on you crazy diamond
DJ Downunder
Post by DJ Downunder »
That does sound about right..you checked it the right way..if there's any oil to be seen it's ok..and only top it up to the center of the sight glass.
btw..I use Castrol Magnitec...that's easy to buy from any auto shop...and will be ok to use.
\\Mike_Lea//
Excellent! It's not gone down dramatically, but I have noticed a drop... A what point (or level in the glass) do you top-up and how much should you add?
M :)
\Mike_Lea// wrote:Excellent! It's not gone down dramatically, but I have noticed a drop... A what point (or level in the glass) do you top-up and how much should you add?
M :)
When you can't see it - and then only put in around 400ml. :)
\\Mike_Lea//
Really, as low as that ! I'll keep a check on it then... I tend to have a quick look after every ride, just in case.
What oil would you recommend? They had motorcycle oil in Halfords last time I looked, Catrol GPS I think it was. Right/Wrong?
M :)
\Mike_Lea// wrote:Really, as low as that ! I'll keep a check on it then... I tend to have a quick look after every ride, just in case.
M :)
IIRC GPS is correct (it MIGHT be GP, I'd have to look).
IIRC the site glass only covers a 500ml "level-change" anyway, so I tend to add 400 if I can't see anything, or 200/300 if I can and if I can be bothered.
chris
Post by chris »
M :)
Hi
I was after GPS and rang Castrol tech to find a stockist so yep Halfords stock it BUT they also recommended adding any 10/40 or 15/40 oil to it as it would get the grade closer to what BM motors need to get run in. They said you can stick whatever you like in there, no danger of damaging the motor!
I was concerned about mixing oils but the tech said they all mix OK and you can basically run our motor on whatever you have lying around in the shed!
Chris
2011 G650GS
Photos
\\Mike_Lea//
Just checked with the local dealership, they recommended Castrol GP 10W40.
Regarding Castrol GP'S'; does the 'S' symbolise synthetic?
M :)
\Mike_Lea// wrote:Just checked with the local dealership, they recommended Castrol GP 10W40.
M :)
or "sport". ;)
TBh - yes you could run pretty much anything - the clutch and gears aren't in the same oil, so all you really need is proper, old-fashioned style, ENGINE oil. :D
\\Mike_Lea//
Had another little look in halfords tonight... GPS is a semi-synthetic oil, aparently. I'm assuming Castrol GP, isn't?
Either way they're both 10W40... My non-mechanical mind can't absorb that sort of information :oops:
M :wink:
