Battery Tender Plus + Odyssey Battery a No-No?
frbank6
Post by frbank6 »
Is this a bad combo? For the life of me, I can't find a straight answer to this question on either the Deltran or Odyssey sites. I seem to remember this topis coming up here before, but I couldn't find the thread.
Arbreacames
Post by Arbreacames »
Battery tender + Odyssey is fine as long as the Odyssey is not severely discharged. If it is, it is necessary to start with a high-power charger.
Carlos D.
GeoffJ
Post by GeoffJ »
I had similar concerns with the gel battery on my BMW. I found the answer on Del Tran's (Battery Tender) we site. They have a very good FAQ page.
'96 BMW R1100R
'05 HD Electra Glide Ultra Classic
Capt. Blackadder
Post by Capt. Blackadder »
The user manual with my Odyssey PC680 states that a 3 amp trickle charger may be used if the battery is in long-term storage or subject to parasitic draining, which is the case with our bike because of the clock. If I recall correctly the Battery Tender Plus only puts out 1.25 amps. That said, it may be fine to use it, I don't know. Just putting this out there as food for thought.
Panzerleder
Post by Panzerleder »
I've been using a battery tender and Odyssey battery for a couple of years with great results.
fnfalman
Post by fnfalman »
Seems to work fine with my combo of BMW-brand Deltran battery tender and Odyssey battery.
jb44
Post by jb44 »
There may be a difference of opinion:
Deltran (Battery Tender):
The chart at the bottom of this page shows the Battery Tender Plus has a 4 step charging program suitable for standard, AGM, and gel batteries:
Odyssey batteries are AGM lead-acid battieries.
http://batterytender.com/selection_guide.php
The Odyssey site says for best results the PC680 needs a 6-7 amp charger (Battery Tender = 1.25 amp)
http://www.odysseyfactory.com/odycharg_b.htm
A year or two ago a message was posted on the Odyssey site specifically not recommending Battery Tenders.
.....anyone else remember this??? or am I hallucinating?....again.
In short, Arbreacames has the right answer. :)
jb
Panzerleder
"In short, Arbreacames has the right answer."
That's basically correct. As I recall, my Odyssey came with a note to the effect that if it ever got "severely discharged" you would need a high-powered, or automotive charger to bring it back up to speed. The Battery tender is a trickle charger intended only to keep batteries fully charged.
