Any guidance would be greatly appreciated!
Garmin Quest Mount
Garmin Quest Mount
Anyone out there using a Garmin Quest GPS on the R? What mount are you using? My GPS should be arriving in a few days and just now realized, what good is a GPS if you dont have a mount!
Try these. They work fine with my R.
http://www.gpsdiscount.com/products/index.html?a=487
http://www.gpsdiscount.com/products/index.html?a=488
I believe you can buy a cradle that will fit the Quest directly from Ram, as well as some other sources. Touratech makes some as well.
http://www.cycoactive.com/ram/quest.shtml
http://65.102.174.116/rammount/productd ... 149z-GA15U
I would go ahead and get the Garmin mount with power. You'll find that the batteries don't last as long as you expected, and then you'll have the option to hook it up. I have the Garmin mount on my bike mounted with the RAM accessories and it's a perfect fit; it holds the unit securely and I don't have to worry about battery power on multi day trips. Plus, using the RAM mounting system, you can easily move the location as you need to, maybe for accomidating a tankbag.SitR1150R wrote:Thanks, but if I dont want to run power from the bike to the unit, do I still need the garmin cradle or does the ram mount come as pictured so the unit just clicks in place?
Back view
Front view low
Front view high
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
I'll second R4R&R - I have the identical setup using the cradle and RAM mounts for my Quest. As you can see in R4R&Rs pix, this works very well.
I use a BMW plug on the cradle's wires and simply connect to the accessory outlet for power. This way, when I want to remove the mount, it's a 30 second job.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
Using the bicycle mount, it's a half second job to mount/unmount. When it is unmounted, you can hardly see the mount at all, it's very unobtrusive.
Also, the battery has lasted all day (20+ hrs) for me no problem. Be sure to turn off the backlight during the day and your battery will last even longer.
best of all, it was only a few dollars.
Here is my review and pics:
http://www.r1150r.org/board/viewtopic.p ... highlight=
'02 R1150R
Thank you all for the help. At least I know now what type of mounts work on our bikes. Now I just need to wait for them to get here so I can play with them and start making some rides! Only problem is the silly weather guy has put the S word back in the forecast off and on for the next two weeks. Give me a break, its almost March, Im ready for sun and dry roads!
Cat --
The USB connection on the Quest is for downloading mapping info from your computer to the unit itself. Charging is via a plug-in transformer (included with the Quest package) from your mains current.
The Quest would be a good choice for a smaller place like Singapore since the unit has limited memory. It's pretty easy to pick new maps with the sw and download the new info though.
'03 R1150R
Life member 365
Life member 365
Thank you all very much for the help on the mount for my Garmin. After some minor computer issues, I got the maps loaded into the silly thing and was finally able to get out on the bike today to try it out. The unit worked perfect and the mount is just as good. No vibration at all, and easily mounts in any spot you want so you can see the screen. Never really though that much of GPS units, but now that I have one, I am sold, its the only way to navigate on a bike.
They can not replace maps! The small screen is hard to find routes around traffic jams (IMO). When you zoom out, you lose the detail of the smaller roads. Also my Quest doesn't route too good in certain city situations. They are great when you program a route to follow, but sometimes I may change my mind on-route.SitR1150R wrote:Never really though that much of GPS units, but now that I have one, I am sold, its the only way to navigate on a bike.
Overall, they are an additional tool to be used but I wouldn't fully rely on a GPS unit.
