The can is off!
mad1150
Donating Member #: 522
The can is off!
Post by mad1150 »
When I was at the autoparts store, they had black tips. I had a chrome one in my hand, but then decided black would look good and I would have to polish it.
I removed the can and installed a black tip but was unable to turn the heat shield around due to the angle of the shield and placement of the clamp.
Any ideas how to paint the chrome heat shield black? Do they make black ones?
Type of paint to use or other suggestions.
Here's some pics:
Mark - Member 522
04 R1150R (Silver)
kantuckid
Post by kantuckid »
You can paint chrome if you first scuff it so the paint will stick. Use wet/dry paper -say 360 grit and primer it , then paint. Better make sure that it isn't too hot for regular paint before you paint it. I have never felt that part to know.
Ves
Post by Ves »
I don't know, looks OK to me. The chrome shield blends in with the catalytic converter and your silver case, and the black pipe blends in with your tire.
chris
Post by chris »
You can buy VHT paint in an aerosol which is good for exhaust temperatures.
Chris
2011 G650GS
Photos
Buckster
Donating Member #: 543
Post by Buckster »
I would just take the heat shield off.
But if want to paint it you can use a high heat engine paint OR BBQ grill paint. Sand it the best you can, it will seem like your barely doing anything to the chrome and use a primer-use the same brand primer as you do paint for best results.
Buckster '03R
#543
DJ Downunder
Post by DJ Downunder »
I would take the heat shield off..and put it on the shelf with the can.
I would cut a couple of inches off to shorten it..then cut a slot about an inch long on the under side.
Then I would buy a nice exhaust clamp and clamp it on the cat...Job done.
But that's if it was me... :wink: ...btw...the black looks great.
MartinW
Post by MartinW »
you can buy cans of black spray paint for painting chimney flues with. it will withstand v high temperatures and is not expensive.
joel
nice
Post by joel »
mad1150 which auto-parts store had the black tips? I love the way the black looks. I have a chrome on mine, but now want the black! I removed my heat shield though, looks cleaner imho.
Mark, looks GREAT! DJ, the slot you mentioned, is that to tighten when using a clamp, instead of the set screws? :)
DJ Downunder
Yes..It needs a slot so it can be clamped tight onto the cat..IMO
joel
more pics
Post by joel »
DJ, can you post pics or have you posted pics of your exhaust setup, with the clamp?
mad1150
Post by mad1150 »
O Reilly Auto Parts
http://www.oreillyauto.com/EW3/HomePage.do
Not sure if it's gonna stay that way.
1) I sometimes ride without earplugs, like to work and back about 15 min. one way. It seems pretty loud. I liked my quiet bike.
2) I now have a vibration in the left foot peg, a little bit on the right, but the left is very noticeable.
Riding all day tomorrow, that will tell me. But at least I can make a little noise with the 100+ HDs I'll be riding with at the JP Cycles Poker Run. Can you say - EARPLUGS!
Mark - Member 522
04 R1150R (Silver)
MIXR
Post by MIXR »
Clamp is a stainless steel band type. Made in Australia too! Only costs a few bucks. I had to get mine from a specialty fastener store, as the exhaust shops wanted 6 times the price for lesser quality. Mine's not noisy, and no vibration. Maybe it's the slight tip angle. Mine is set up to direct exhaust gas down and slightly outboard, to keep the wheel clean.
DJ Downunder
Hey Mick...it's the same clamp as mine.. :smt023 ...did you put a slot in your tip so can be tightened properly?
joel
great pics
Post by joel »
Great pics DJ and Mixr. Thank you! :D
MIXR
Post by MIXR »
From an engineering standpoint - three slots work better than one or two. Allows for a more even contraction of the pipe around the cat outlet so that it doesn't distort it, just in case you need to put the original can back on. It also allows you to keep the slot length to a minimum. My cuts are only a few mm longer than the width of the clamp. Having three sections of the tip able to comppress (three slots) means that the tip end is evenly pressed against the quite thin cat outlet.
The clamp doesn't need to be wound down as tight (easier removal later) and the slots collect less crud and water, so less corrosion at the clamp. Too many slots, and the tip is likely to be weaker. Anyway - Lots of theories on that sort of stuff, and people can please themselves. That's what I did.
I've sent a couple of those clamps to people in 'obscure' places (like the USA) when they just couldn't find them locally.
UBU
Post by UBU »
Just a quick addendum to the excellent reply by MIXR.
Another reason to keep the slots as short as possible is to eliminate any possible sources of air leaks (which cause the dreaded exhuast banging on overrun).
Rog.
From the planet Zephyron.
Models owned:- Rog (Yorkshire Dales)
MIXR
Post by MIXR »
Rog - Don't know that that's an issue, because the tip is so short anyway. The natural 'popping' on overun (in every 1150 I've ridden) that gets damped by the can is much more noticeable with the short tip. It's not a loud 'bang', just a soft pop. I don't mind it. Some hate it.
You still raise a valid point about the short tip sealing correctly though. When I first tried mine, I had it pretty loose. It definitely leaked. For some reason, the exhaust seemed to be noisier because of the leaks, even though the outlet was only a few inches further back. It was quieter when I tightened everything down.
Mine's been in place for 65,000 kms, and my service guys don't have an issue with it. It scrapes in under our noise limits (95 or 97 dBA - Can't remember). The tip on my bike was a standard heavy-duty auto one. I cut about 4 inches off the straight end as it was a bit too long and looked too 'dorky' hanging way back to the rear wheel centre. It's only job is to make sure the hot exhaust is directed away from the side case, and away from the tyre/rim.
mad1150
Post by mad1150 »
Well, after riding 450+ miles yesterday without the can, it goes back on today! Maybe all the cool kids are doing it, but if all the cool kids jumped off a cliff...
I reached the following conclusions (sorry in advance Harley owners):
1.) If I wanted a loud bike, I would have bought a Harley.
2.) If I wanted a bike that vibrates, I would have bought a Harley.
3.) I want it even quieter with less vibration (I think I just said R1200R)
I rode for 3 days straight in WI last month with only occasional right hand numbness. At the end of the day yesterday, my ears, feet, hands, and rear-end were all bothering me, and I was extremely tired. Could have been an off day, but I think it was the vibration.
Mark - Member 522
04 R1150R (Silver)
DJ Downunder
That's the good thing about doing this mod..If you don't like it you just put it back on.
Imagine paying $500 for an aftermarket can...and then putting the stock can back on..because you don't like the added noise.
I think this mod is more suited to around town riding (what I do the most)..not so much for touring.
I have never had any added vibration with this mod..my bike is as smooth as silk.. :D
