battery maintenance through accessory port
Posted: Tue Aug 14, 2007 3:34 am
by texbid
Are there any reasons not to use the accessory power port for a battery maintenance plug in port?
VP
Posted: Tue Aug 14, 2007 3:58 am
by DJ Downunder
I don't think so...That's what it's there for.. :D
Posted: Tue Aug 14, 2007 5:20 am
by MartinW
I use mine for this purpose - absolutely fine as the current draw is very low.
I have a separate socket with heavy-duty cables for jump-starting. Have never had to use it but it's good insurance against a flat battery!
Posted: Tue Aug 14, 2007 7:04 am
by OU812
Everyday. The BMW charger came with the plug for it, so it must be OK. :wink:
Posted: Tue Aug 14, 2007 11:44 am
by Sunbeemer
I believe the auxiliary plug is protect by a 15 amp fuse, and there aren't many battery chargers that put out that much current, so it should be fine. Trickle chargers typically only put out ~ 1-2 amps.
