battery maintenance through accessory port
texbid
Post by texbid »
Are there any reasons not to use the accessory power port for a battery maintenance plug in port?
VP
Post by DJ Downunder »
I don't think so...That's what it's there for.. :D
DJ
MartinW
Post by MartinW »
I use mine for this purpose - absolutely fine as the current draw is very low.
I have a separate socket with heavy-duty cables for jump-starting. Have never had to use it but it's good insurance against a flat battery!
Everyday. The BMW charger came with the plug for it, so it must be OK. :wink:
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
I believe the auxiliary plug is protect by a 15 amp fuse, and there aren't many battery chargers that put out that much current, so it should be fine. Trickle chargers typically only put out ~ 1-2 amps.
