Have just started riding my "new" 04 r1150ra.
25k miles
Did spend some "quality time" with my rider's manual -
there's as many switches, buttons, and indicator lights
on that as there is on my car!
Anyway, have notice that the brake warning light flashes
for maybe 30 seconds after I start the bike cold.
Then the light goes out, doesn't flash any more, and the
brakes seem to work just fine.
Is that a problem, or normal? I hope it's not a symptom of
that ABS unit going out? Or is the system just building pressure?
Thanks for any info!
ABS Question
- bmwr1150rbmw
Re: ABS Question
That is exactly what is supposed to happen. It turns off when you reach 2-3 mph. If that sequence you described changes, then you have a problem.
Re: ABS Question
Thanks!! MAJOR relief!
Understand that's an expensive system to repair.
Didn't notice anything about that particular situation when I read thru the manual.
Happy Motoring All!!
Re: ABS Question
The ABS system will flash the light until the front wheel has done a complete rotation - this is the ABS system calibrating itself (or something).
