The other day I swapped out my headlight for one of the fancy superwhite premium bulbs. The job went smoothly, but inside the headlamp itself, I found another, tiny, 12V bulb. What's this one for? Maybe a running light? I am in Canada, so of course, our machines are wired to run with the headlight all the time. Is it different in other jurisdictions?
Cheers,
R
What's this lamp for?
My favourite website:
Make a Small Loan, Make a Big Difference - Check out Kiva.org to Learn How!
- stilldking
- Double Lifer
Re: What's this lamp for?
It's the Parking Lamp.
When you turn the ignition key to Park, it turns on with the tail light. (In theory at least.)
JC
JC
John C
Ahh, I see. It's never worked since I've had the bike, 'cuz it's burnt out.
I will replace it at first opportunity, so that I can do some grade "A" parking.
Don't park for long or you'll have a dead battery because the tail light is also on.Ritchard wrote:I will replace it at first opportunity, so that I can do some grade "A" parking.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
My tail light is a 5 W luxeon LED 1157 replacement. With that I could park for a good long time without worrying about the battery.
- stilldking
- Double Lifer
Speaking of LED's, is there a bulb type that'll fit in for the headlight parking lamp?
JC
JC
John C
- stilldking
- Double Lifer
After a little research (very little), I may have found something that'll work.
This shows it's for "LED replacement bulb module for the Parking lamp in BMW headlight assemblies."
http://www.cyclegadgets.com/Products/pr ... sp?Item=RV
This "should" limit current draw and have a more substantial life than standard filament bulbs. (Provided it's the correct size.)
Sorry to resuscitate an old threat, but thought someone might be looking for this as well.
JC
JC
John C
