What's it like? I'm finding out as I dig deeper "under the hood" and swap
some of the Farkles from my 50R.
The headlite' nitetime illumination is superb. It even fully illuminates the peripheral sidelines into the woods, much needed on sharp corners at nite. Driving lites that were necessary on my 50R were put into cold storage . . . . not needed unless I'm on roads as tight as 129 thru the Dragon. Everything on and of the bike has placed weight and simplicity as a high priority. My F800 engine sidecover bolts have an 8mm hexhead with a T-30 Torx
inside it! See it in the center of this pic:
Talk about weight reduction . . .
with dual functions! It's the first time I have ever seen those type of bolts. A little thing, yes, but indicative of the clever, extra effort, designed-in weight frugality and bright thinking also applied in areas you can't see. My bike gets better fuel economy, routinely 64 +/- 1 MPG, than any 600+cc single cylinder bike streetbike. That does not happen without some very deep thinking and engineering expertise. Doing so with precise fueling and throttle response is nothing short of a miracle!
Look at the blue painted screw in the center of this pic and the minimalist, robust steel, NO CABLES quality around it. The synch is done once at the factory and won't need adjusting for
years. Also note the sheltered out of the weather, and from being bumped, the quite small TPS on the right side.
Now look at the WFO (WideFriggenOpen) position:
They even solved the troublesome heated grip wire problems with a very simple low/no cost solution. The grip wire no longer goes through the inside of the handlebar. It's a big 360 degree circumference loop inside the throttle that winds to a smaller (loose) loop when turned towards full throttle.
This exterior heated grip wiring allows the handlebar to be filled with nail spikes and RTV goop to really smooth out the vibes in some upper RPMs
-AND- the use of a standard, slightly higher (and/or narrower) handlebar, with an available 4" brake hose extension the one likely needed extra expense.
EDITS: Change to faster, better, less invasive photo provider.
