Hotgrips
holdfastking
Hotgrips
Post by holdfastking »
My left side heated grip has a broken wire in the element itself. I would like to replace both grips with "Hotgrip" brand grips. Has anyone used these grips with their existing factory wiring and switch? If so, do you happen to know what part number I should order for my Rockster? I hear that their grips are way better than the factory ones, but I don't want a bunch of new wiring if it isn't necessary. Thank You.
joe bar
Re: Hotgrips
Post by joe bar »
My left side grip also packed up. I used a Symtec heater element and wired it into the existing switch. Both side working fine and very similar in output.
