Muffler lowering kit for 2002 R1150R
f4tweet
Post by f4tweet »
Does anybody have a muffler lowering kit? It was a three piece kit that was used on Police GS's to allow them to run a full sized left bag. Any help would be appreciated, thanks.
02 R1150R Black
Armo
Re: Muffler lowering kit for 2002 R1150R
Post by Armo »
I believe I do. I have some attachments that lower the exhaust. let me go home and find the pics of it and see if thats what you are looking for.
f4tweet
Post by f4tweet »
Thanks.
02 R1150R Black
macx
Post by macx »
This may not lower it enuf for your purposes, but it was all I needed to run my bags without fear of melting the bottoms.
If nothing else, maybe it will give you some ideas.
http://s719.photobucket.com/albums/ww20 ... g&newest=1
Nothing fancy (or expensive) at all - only needed to lower the muffler about 1-1/2" or so.
Loosened the joint at the front of the muffler, undid the bolt in the middle of the muffler, put some weight
on the back end of the muffler (stood on it), used a short piece of shiny strap metal (could use galvanized
or aluminum, worked OK for me, was behind the bag anyway) with a hole in ea end, reused the original
mounting bolt to fasten the bottom end of the strap to the muffler with a SS self lock nut, got a short SS bolt to fasten the top of the strap to the original muffler mounting point. Retightened the muffler clamp, no leaks.
If you try to go much lower, you'd probly need a 45 deg exhaust elbow of the appropriate size, chrome or whatever, and cut it to obtain the proper degree of lowering, like 30 deg for instance. You could still use a flat polished aluminum strap.
f4tweet
Post by f4tweet »
Thanks, good idea and simple.
02 R1150R Black
