2004 R1150R Idle rpm decreases when front break is engaged
- MoonBeemer
Ok riddle me this batman, why does the idle decrease by a hundred RPM when I engage my front break when I am sitting at a light idleing?
2004 R1150R
Re: 2004 R1150R Idle rpm decreases when front break is enga
Do you have ABS?
- MoonBeemer
Yes I have ABS and I run with my bright beams (stock lighting) on. I had not thought of this until today. Additionally, the ABS is showing no fault codes as far as the lighting on the triple plate goes. Thanks.
2004 R1150R
ABS pump puts additional load on electrical system--i.e.-alternator which loads down engine---decrease in rpm.
Wayne, you can be "Batman". I'll be "Robin".
- iowabeakster
Don't worry. My bike does that, too. It has since new.
