Fast Blinker
Posted: Fri Aug 17, 2012 7:42 pm
by Bluehenrider
I just noticed my right turn signal blinks extremely fast. I am assuming a relay somewhere is going bad.
Re: Fast Blinker
Posted: Fri Aug 17, 2012 11:29 pm
by swamper
Maybe the wrong bulbs.
Re: Fast Blinker
Posted: Sat Aug 18, 2012 1:38 pm
by ColumbiaBMW
My bike has had the same problem for over a year now, and I've started a couple of posts about it. I've taken it to the shop (they couldn't duplicate the issue since it only does it sometimes, so they couldn't do anything), I've replaced the bulbs, and I even bought a new turn signal relay off someone on here, and that didn't do any good either. Good luck figuring it out, and be sure to let me know what it is when it gets fixed.
Re: Fast Blinker
Posted: Sat Aug 18, 2012 8:43 pm
by Bluehenrider
Thanks for the posts.
Re: Fast Blinker
Posted: Sun Sep 16, 2012 7:55 pm
by Bluehenrider
Fast blinker stopped on it's own. No idea why.
Re: Fast Blinker
Posted: Sun Sep 16, 2012 8:10 pm
by kirby
3463
Re: Fast Blinker
Posted: Tue Sep 25, 2012 2:55 am
by sadani99
Hi there!
I had same problem but i've solved it.
The bulbs in the bike where 10 watt and the default is 21 watt that was the problem maybe, when the bulbs are too big you can buy smaller bulbs but when you need yellow, you must paint it.
The 21 watt smaller bulb:
http://www.ebay.com/itm/AUTOMOTIVE-LIGH ... 4d00e7ba07
I hope it was useful..
Re: Fast Blinker
Posted: Wed Sep 26, 2012 10:03 pm
by ColumbiaBMW
Bluehenrider wrote:Fast blinker stopped on it's own. No idea why.
The issue will most likely come back again, mine always does that too. It will blink fast, go away a few days, do it again. And I went through everything like checking all the wires, indicator bulbs, even bought a new flasher relay. Nothing ever worked, but then tonight I saw this thread on advrider:
http://advrider.com/forums/showthread.p ... ght=r1150r
So after reading about how the problem came from his pilot light in the head light, I went and checked mine, and sure enough it was completely burnt out. So tomorrow on my way home, I will definitely be stopping for a new bulb, and hope that solves my problem.
