Heated grips fuse
Posted: Sun Aug 25, 2013 7:42 pm
by Obard
What am I doing wrong? I have a 2002 r1150r abs, and I added a headlight modulator and the MotoTechniques handle bar risers. Since adding these accessories, my heated grips blow their fuse instantly upon turning them on. Worked fine before this, I think. I must have mucked something up, but I haven't found it yet? Any help would be appreciated. Thanks
Re: Heated grips fuse
Posted: Mon Aug 26, 2013 11:42 am
by Bruce H
you have a short on the wire when it was pulled on to install your accessories. most likely it was the bar risers but you might disconnect the modulator first and see.
Posted: Mon Aug 26, 2013 1:32 pm
by towerworker
Did you cut the zip ties that hold the wiring harness tight around the steering head? Those ties are historically too tight and cause such a failure.
Posted: Mon Aug 26, 2013 8:29 pm
by Obard
Bruce H wrote:you have a short on the wire when it was pulled on to install your accessories. most likely it was the bar risers but you might disconnect the modulator first and see.
I was afraid of that. Thanks for the reply.
Posted: Mon Aug 26, 2013 8:34 pm
by Obard
towerworker wrote:Did you cut the zip ties that hold the wiring harness tight around the steering head? Those ties are historically too tight and cause such a failure.
I cut the zip ties before installing the risers (per the install directions). What I didn't do was have someone hold the bars while I installed the risers (per the install directions). Darn things worked great before this. Argh! Thanks for the reply.
