Bike winterizing
Steve H.
Bike winterizing
Post by Steve H. »
Hi,everyone!
Here in the north,the winter is knocking on our doors.-Global warming??-well I am not so shure.Anyway,I am not driving my bike below40F.Love and respect it soooo much!!Best winterizing of the bike-greatly appritiat your inputs.
Thank you in advance
Steve H.Northumberlander
1200bc
Re: Bike winterizing
Post by 1200bc »
I change the oil and filter, if it has any miles on it, fill the tank and add a stabilizer, wash and dry it, move into walkout basement, attach the bmw charger, dust cover and then cry.
David R
Post by David R »
SUX don't it?
I just park it. I fire it up once a month for the bikes good and mine. It gets warmed up until the temp gauge is at normal, then I let it go back to sleep. I have 4 bikes in the garage, so it will take a good part of a day. All the tanks are full and oils have been changed. I put a trickle charger on once a month except my R1100RT which has an Odyssey PC680 battery that I think it will hold its own. This winter is a test. If it passes the test, that type battery that will go in my R1200R.
David
Newportcycle
Post by Newportcycle »
1200bc wrote:I change the oil and filter, if it has any miles on it, fill the tank and add a stabilizer, wash and dry it, move into walkout basement, attach the bmw charger, dust cover and then cry.
+1.
Once a week, setup the hair dryer; with the warm air blowing in your face, sit on the bike, close your eyes, grab the handle bars and make Vroom Vroom noise's.
captaincable
Donating Member #: 1050
Post by captaincable »
David R is right about how to use a charger once a month or even a couple of months, Do NOT not ever put your batteries on some kind of charger or "Tender" and leave them on it unless you just like replacing them , I don't care what the manufacture says about the super duper charger it will not do your battery any favors under long term use, just top it off occasionally.
I also agree with the following procedure:
Enjoy
Mike
Bob Ain't Stoppin'
Post by Bob Ain't Stoppin' »
My brother had a good method for keeping batteries topped up. Plug your charger (or tender) into the light on your garage door opener. Then you get 5 or 10 minutes a day charging. Works great :D
I just plug the tender for about 1 day each month and it works. My '08 bike is still on it's original battery.
vroomr
Post by vroomr »
Just started my bike after it sat untouched for nine months. I did not have the battery on a charger. When the time came to ride, the battery needed all of thirty minutes to come to full charge, whereupon I installed it, pressed the starter button, and smiled.
When I put the bike away I put stabilizer in the fuel, removed the battery, and covered the air intake snorkel and muffler.
The end.
Richard
If your bike is in an outdoor shed or a basement without a dehumidifier, you'll want to clean and car wax the exposed chrome forktubes. A very oily rag's complete wipedown also works on the forktubes and it'll slow aging of both fork slider's wiper seals. A mild mix of Dawn dish detergent washing in the spring will remove the dusty gooey oily mess, no problem.
If it's an outdoor shed I would also fully oily-rag coat the exposed shaft of the front and rear shock absorbers to guarantee prevention of rust pits.
Those 2 chromed forktubes and shock absorber shafts will be a VERY expensive repair, not IF, but WHEN they develop rust pits, caused by normal outdoor moisture condensation from the everyday temperature swings.
A 5 minute engine run on a full tank of gas with fuel stabilizer added is also a must if you are a fair weather rider.
