caliper rebuild kit (Rockster w/Tokico calipers)
mambopalace
Anyone know if caliper rebuild kits are available WITHOUT pistons for Rockster. (Tokico)
Re: caliper rebuild kit (Rockster w/Tokico calipers)
Contact board member Riceburner. He's got more experience with our brake calipers than anyone else.mambopalace wrote:Anyone know if caliper rebuild kits are available WITHOUT pistons for Rockster. (Tokico)
mambopalace
OK thanks, I sent him a message.sweatmark wrote:Contact board member Riceburner. He's got more experience with our brake calipers than anyone else.mambopalace wrote:Anyone know if caliper rebuild kits are available WITHOUT pistons for Rockster. (Tokico)
Answered your question in the Rockster section of the forum.mambopalace wrote:OK thanks, I sent him a message.sweatmark wrote:Contact board member Riceburner. He's got more experience with our brake calipers than anyone else.mambopalace wrote:Anyone know if caliper rebuild kits are available WITHOUT pistons for Rockster. (Tokico)
But - to recap (and provide search results) - you can more than likely get them from a Kawasaki Dealership. Kawasakis (especially the ZXR models) used Tokico callipers - do a little searching for a bike which has the same calliper dimensions (ie piston diameters) and then chase down the parts from a Kaw dealership.
In the UK I've been able to source bits from Cradleigh Kawasaki - I'm sure there'll be someone as useful in the States.
Also - as said in the other post - if you're going to spit the callipers (makes getting the pistons out and cleaning everything up much easier) - you'll need to replace the 2 small seals that fit in between. BMW will NOT sell you these - but Kawasaki will.
mambopalace
It appears that the front TOKICO calipers are:
Small Piston 32mm
Large Piston 36mm
The 32mm is the dust seal.
The 36mm is the pressure seal.
Now...Try and find 'em.
Small Piston 32mm
Large Piston 36mm
Best of luck!
- hank
Some more info here including Honda and Kawasaki part numbers for the seal that BMW dont supply
viewtopic.php?f=2&t=30348
mambopalace
The small O - Ring (Joint Seal) between the caliper halves part numbers are:
Kawasaki 43049-1004
Honda 45103-MEL-003
Kawasaki 43049-1004 RING,SEAL, 6.5 X 11.5 X 2.2 (SEAL BETWEEN CALIPER HALVES)
Thru research, I found that the Honda pieces are about 2/3 the price of the Kawi seals.
I ordered them from Partszilla for 96 cents each.
Now, does anyone know where the 32mm dust seals and 36mm pressure seals can be obtained from OTHER than BMW?
BMW wants $98 for the seal kit with piston. I don't need the pistons.
Kawasaki 43049-1004
Honda 45103-MEL-003
mambopalace
I received Honda part #45103-MEL-003 Today.
RING, SEAL Joint - 6.5 X 11.5 X 2.2 (SEAL BETWEEN Tokico CALIPER HALVES)
I can confirm that these are the correct O Ring seals between the caliper halves.
They were 96 cents each from Partzilla.com
