Does anyone have an outlet for caliper rebuild kits for '04 Rockster / Tokico calipers.
The size of the seals would be helpful also.
I only need the rubber seals and not the pistons.
Thanks,
Caliper Rebuild kits Tokico for Rockster
mambopalace
Re: Caliper Rebuild kits Tokico for Rockster
you may be able to buy all the seals individually from a Kawasaki dealership. I've only ever seen them available as a (semi)* complete kit from BMW.
* - the BMW kit doesn't include the 2 seals that sit between the calliper bodies. If you split the callipers, you would be best off replacing these seals - again - available via Kawasaki dealers.
mambopalace
OK, thanks.
It appears that the front TOKICO calipers are: Small Piston 32mm
Large Piston 36mm
Now...Try and find 'em.
Large Piston 36mm
- hank
The seal that goes between the caliper halves can be found at Kawasaki and Honda dealers.
Kawasaki (part no. 43049- 1004) or Honda (part no. 45103-MEL-003)
mambopalace
mambopalace wrote:Does anyone have an outlet for caliper rebuild kits for '04 Rockster / Tokico calipers.
Thanks,
The small O - Ring (Joint Seal) between the caliper halves part numbers are:
Kawasaki 43049-1004
Honda 45103-MEL-003
Kawasaki 43049-1004 RING, SEAL, 6.5 X 11.5 X 2.2 (SMALL SEAL BETWEEN THE CALIPER Sides)
Thru research, I found that the Honda pieces are about 2/3 the price of the Kawi seals.
I ordered them from Partszilla for 96 cents each.
Now, does anyone know where the 32mm dust seals and 36mm pressure seals can be obtained from OTHER than BMW?
BMW wants $98 for the seal kit with piston. I don't need the pistons.
mambopalace wrote:mambopalace wrote:Does anyone have an outlet for caliper rebuild kits for '04 Rockster / Tokico calipers.
Thanks,
Kawasaki 43049-1004
Honda 45103-MEL-003
As I said - if you can chase down the a Kawasaki with the same piston diameters then Kawasaki sell all the bits individually.
mambopalace
I've searched 5 Kawi dealers for the 32/36mm seals for Tokico calipers - They have been Unable to locate them in the system via computer or phone.riceburner wrote:mambopalace wrote:mambopalace wrote:Does anyone have an outlet for caliper rebuild kits for '04 Rockster / Tokico calipers.
Thanks,
Kawasaki 43049-1004
Honda 45103-MEL-003
Anyone that can shed any further light on this, please do.
mambopalace
I received Honda part #45103-MEL-003 Today.
RING, SEAL Joint - 6.5 X 11.5 X 2.2 (SEAL BETWEEN Tokico CALIPER HALVES)
I can confirm that these are the correct O Ring seals between the caliper halves.
They were 96 cents each from Partzilla.com
