Rotor bolts
jasondo
Rotor bolts
Post by jasondo »
What type of lock-tite should I use to tighten the bolts. Also what is the torque required for the rear rotor?
Keppelj
Re: Rotor bolts
Post by Keppelj »
Torque is 40 nm. Don't think lock-tote is called for.
Re: Rotor bolts
jasondo,
Use the "semi permanent" Blue Loctite. No heat required for removal, just extra removal torque after it has cured.
Because of the tremendous rotational back torque and varying heat cycles, it is not a good idea to omit the Blue Loctite.
