Hi guys
Does anyone know if washers must be placed under the bolts which connect the front brake calipers to the legs?
When I cleaned break(pads) I noticed there weren't any under the bolts and the legsurface where the bolts rest on look pretty deformed.
User guide isn't clear about this.
Other: Is it recommended to replace fuel filter by myself?
(excuses for bad grammatic)
Thank you
Washers to expensive
- Smoothrider
Cant comment on the washers at the moment but I changed my fuel filter last week. It took about 2 hours; you need to remove the tank to get access to the pump and filter. You may need a new rubber O ring gasket and I recommend you put "jubilee" clamps on in place of the original clamps which you will probably damage as you remove them. Its an easy job If you take your time.
Geoff Thompson
R1150R (Silver)
R1150R (Silver)
Washers on Brake Caliper Bolts.
I looked in the repair manual and there are no washers shown on the diagram.
