Nothing earthshaking about this add on, but it is becoming more important to have a USB port for phone, camera, gps, etc. The USB port pictured here is "water resistant" not water proof, but has a nice fitting cover and it is behind the wind screen. I used heat shrink tubing to cover the wires and give it a cleaner look. Just tuck the wiring up under the tank cover and thread through seat mount or wherever you choose. I used a right angle DIN plug for the socket under the right side of the seat. Also used heat shrink tubing to cover the wires that led into the plug. You could also just purchase a right angle DIN plug that has the USB port. I wanted to have the USB port up by the handlebars to accommodate my tank bag and or when I use my RAM mount for the phone.
Your looking to get 5v/2a output to charge/run your devices. It has a no-load drain of about 0.006 to 0.007 ampere. You could install an on-off switch, but since I use a Smart Charger most all of the time when not riding the bike, I'm going to leave mine connected.
Remember the days when you just rode - no phone, no gps, no gadgets? There is however, a good reason for being connected.... safety.
