...and more specifically, the return spring. I'm pretty sure that with some maneuvering/swearing I could get it off, but I'm thinking ahead to re-installing it. Any tips/tools/suggestions? Doesn't appear to be any leverage points in the vicinity to stretch the spring back into place. Maybe I'm overthinking it but hoping to be prepared before I start the project so I don't wind up staring at the spring for days trying to imagine it back on the bike!
. Maybe I'd get lucky and by undoing the master cylinder plunger rod from it's pin and loosening the bolt that contacts the light switch that it would just slip off and on but the way my luck's been going it's doubtful.
By way of background, I'm still in the foot peg lowering stage and dealing with the new foot relationship to the brake pedal. I've managed to find a used brake pedal and have fashioned an extension for the 'foot' part that's just an inch longer and if works will alleviate the need to pivot my foot inward to reach the pedal. The pivot is the result of the lowering kit off-setting the foot pegs by an inch or so outward.
As always, appreciative of any input-
Here's a rough version of the new pedal. If this works, I'll dress it up a bit with a proper fitting bolt and a rubber cover.
