I have the BMW Sport windshield on my R1150R and would like to change to the Touring windshield. Looking at catalogs, I find that both windshields use the same mounting kit. However, I find that you can purchase the mounting kit separately, but there is no listing for just the windshield (without the mounting kit).
I have talked to my local dealer, Bob’s BMW, and Santa Cruz BMW. . . all are looking but no one has found a part number for the shield only.
Any help out there?
Changing windshields
peterbulgar
If you can't order a BMW Touring Screen without the mounts, consider a screen from CEE Bailey:
http://www.ceebaileys.com/bmw/1150rws.html
I have the BMW Touring Screen, which suits me OK, but I also have a CEE Bailey sport screen and I'm very happy with it. Good quality, no problems, and it fits the BMW mounts just fine. I believe that their standard touring screen is the same height and slightly wider than the BMW screen. They offer several choices - slightly higher, shorter, domed top, euro top, tints.
peter
'73 R75/5, '04 R1150RA
peter
windshield
You can check out the used market also, both here and at IBMWR.org
Even is a used one comes with hardware, it will be cheaper than new. Then you will have backup bolts and hardware.
Vann - Lifer No. 295
Well I do appreciate the information, however . . .
The Max BMW parts fiche only lists two windshield, neither of which is the Touring (or the sport, for that matter) and take completely different mounts. The local dealer had this and couldn’t find anything either. His “paper†parts catalog listed the Touring with mount and the mounts separately. (Which is where I started from.)
I did get an email from Santa Cruz BMW who insists that the part number (99 99 0 000 458) that I have for the touring windshield kit is only for the bare shield and the mounting kit has to be purchased separately. They quoted me the same price as for the full set. Just a little whining here, but I think they want to sell me the kit and just send me the windshield, as I have found the thing in three catalogs, one of which even said in the description of the mounting kit that you would not need this kit if you purchased the windshield kit.
Duh!
As for the Cee Bailey suggestion, I have one for my FZ1 Yamaha and it creates more noise at 30 mph than most do at 100. I used it one time and shelved it.
Thanks for all the input, but unless someone has the actual part number . . .
Duh!
geogridshorthair
areo flow wind screens
I just bought and installed the sport screen from AEROFlow. I love it.
Very quiet and no turbulent air behind the screen.
Uses it's own mounting bracket and was very easy to install.
If you want pictures just email me at:
stevemiller (at) laderasystems (dot) net
I'm 5'6" and I look over the screen by two inches and have no wind hitting my helmet. The touring screen would have been too tall for me.
I also checked out the CeeBaily screen but I prefer the AeroFlow because the plastic they use is not brittle. I have found the CeeBailey plastic to be brittle.
Just my opinion though.
steve
steve
02 Ducati S4 Nakid Sex on two wheels
04 Ducati ST4s w/abs WAY RED
07 BMW K1200R Sport
07 BMW K1200R Sport
Peterburglar,
Do you have any pics of the CeeBaileys sport shield mounted on your bike?
On buying the shield with or without the mounts, don't sweat it. I bet there are people on the board looking for the mounts, and you could probably work some kinda deal.
Monerai, why don't you send it back to them? I have heard that they will work with you if something is not right. It would be worth the try.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
'17 F800GSA
'04 R1150R
peterbulgar
Jeff,
I went for the dark tinted screen. It's also available in light gray and clear. Let's see if the picture is still out there:
http://r1150r.smugmug.com/gallery/618019
Yup, still there. You will notice that the CEE Bailey screen is a bit wider than the BMW Sport, and doesn't come to a point at the top. I think it gives a little more protection than the BMW Sport, and looks better, but of course that is subjective.
peter '73 R75/5, '04 R1150RA
