Brake Failure light ?
Blitz
Post by Blitz »
Bike has been sitting for a bit with the battery tender to keep the juice, I fired it up today and the "Brake Failure" light was flashing. Anyone know why this would happen when it was not occurring before I parked it? Is it just a reset thing or ?? I'm puzzled. ( Oh yes, it has ABS)
A man who knows others has wisdom,
A man who knows himself has enlightenment
2004 R1150R SILVER
jetblack
Post by jetblack »
Check that you rear brake light switch is working properly mine was sticking and that caused the same problem.
jimcameron
brake fault flash
Post by jimcameron »
Not to state the obvious, but does the light continue to flash after you have ridden off, or just after you start the bike?? I'd guess that if you ride off and it continues to flash your battery is due for replacement. Is the 04 equiped with a gel battery? Are you using a gel-battery compatable charger?
JimC
P_Jensen
Donating Member #: 1130
Brake Failure Light
Post by P_Jensen »
You should check the owners manual, the brake failure light flashing can mean several things, everything from a brunt out bulb to low fluid. Which of the two lights which is flashing and the rate of flash (fast or slow) will indicate the fault code. Mine will indicate low fluid in the control unit when parked on the side stand on a downhill slant. Dealer has checked and said it is fine??
P Jensen
14 R1200R
Montego Blue
NW VT USA
