I have an Odyssey PC-680 that is a couple years old. I've noticed that I have to constantly recharge the battery if the bike sits for more than a couple days. Is this a case of my battery going bad or could it be something else like the alternator not charging the battery? The battery takes a charge but it might not be holding it very well. I don't really remember this being 'normal'. Thanks.
2002 R1150RA 25K miles
Battery or...?
Battery or...?
2002 Atlanta Blue R1150RA 26,000+ miles
Jax
Sounds like the battery. Have it tested. A bad battery will over work the alternator causing failure, also will put a strane on other electrical parts, blown light bulbs ect. Also ck the alt. belt if it is slipping (and ytou my not hear it) it can cause the alt. not to charge and run the batt. down. Good luck.
R.D
