Power Accessory socket.
Did the 2004 Rock come standard with one power socket? And where is the best place to mount a second socket (hidden) to power a gps, radio, etc?
I have a power socket on the left side of the engine.
Added a second socket up front at the bottom of the display panel...
Used the screw that holds the display panel frame in place as the anchor point.
I talked at length with one of the techs at Bob's BMW (Steve) before bringing my bike in to do the install. Steve designed/installed it for me. I wanted something that wouldn't look embarassing.
Yup. It was pricey (just under $300), but I'm happy with it and have no worries about how durable it will be.
Pam
Pam
Was the socket on the left side there during the time of purchase? The reason I ask is that my bike was suppose to come to me with the power socket, and according to the folks staffing the BMW web site, it is on the bike (I'll ask the service folks at my 6K) but all I can find is the open area above the peg with a blank cap.
That is a nice set-up on your bike.................
I discovered I had that too.jas wrote:Was the socket on the left side there during the time of purchase? The reason I ask is that my bike was suppose to come to me with the power socket, and according to the folks staffing the BMW web site, it is on the bike (I'll ask the service folks at my 6K) but all I can find is the open area above the peg with a blank cap.
Make sure you get the specific part, not the "Retro-fit-kit" for the plug - they ARE different. The standard one plugs straight into the loom and there should be a socket just behind that plastic cover to fit it.
sorry for the miss use of the quote. Love my new Rockster and the Message Board still learning how to use them both!The standard one plugs straight into the loom and there should be a socket just behind that plastic cover to fit it.
I can't seem to locate the "socket just behind the cover to fit it." Can any one make a suggestion?
Welcome.sinned wrote:sorry for the miss use of the quote. Love my new Rockster and the Message Board still learning how to use them both!The standard one plugs straight into the loom and there should be a socket just behind that plastic cover to fit it.
Take the plastic cover off (one small hex-screw at the rear end, then the plastic cover will pull off). The "flying-end" of the loom will be tucked away behind the startermotor. It might feel weird pulling at the cables, but if you're reasonably gentle you won't do any damage. the flying-end with the small socket on it should pull out, it's not long though, just long enough to reach the power socket when you've fitted it on.
Thanks to this I finally found that well-hidden "flying-end", thanksriceburner wrote: Take the plastic cover off (one small hex-screw at the rear end, then the plastic cover will pull off). The "flying-end" of the loom will be tucked away behind the startermotor. It might feel weird pulling at the cables, but if you're reasonably gentle you won't do any damage. the flying-end with the small socket on it should pull out, it's not long though, just long enough to reach the power socket when you've fitted it on.
Anybody knows if it's possible to charge the battery using this power socket?
ibux
'08 Titan Silver Metallic / Magma Red R1200S
Yes. That's how you conveniently recharge the battery with the battery tender. You can either get the BMW-branded Battery Tender that comes with the power socket plug, or you can get a regular Battery Tender (which is the same damn thing without the Roundel Tax) and buy a BMW power socket plug adapter.ibux wrote:Thanks to this I finally found that well-hidden "flying-end", thanksriceburner wrote: Take the plastic cover off (one small hex-screw at the rear end, then the plastic cover will pull off). The "flying-end" of the loom will be tucked away behind the startermotor. It might feel weird pulling at the cables, but if you're reasonably gentle you won't do any damage. the flying-end with the small socket on it should pull out, it's not long though, just long enough to reach the power socket when you've fitted it on.
Perfectfnfalman wrote: You can either get the BMW-branded Battery Tender that comes with the power socket plug, or you can get a regular Battery Tender (which is the same damn thing without the Roundel Tax) and buy a BMW power socket plug adapter.
http://www.ctek.com/EN/MXS3600/accessories.asp
As shown there is a cigarette plug available, which I could use together with this:
http://www.bmwsantacruz.com/Merchant2/m ... ct_Count=0
I was, however, hoping to find an adapter that fits directly between my charger and the power outlet mounted on the bike. Anyone seen this?
ibux
You could wire this directly onto your charger leads:
http://www.powerletproducts.com/product ... ockets.php
But be careful that you match the charger to the battery. BMW's use different chargers for lead-acid batteries, and their gel-cell unit.
Since finding an adapter that would fit directly between my charger and the power adapter proved difficult, I bought an adapter from a local dealer (similar to the ones Powerlet make).NoRRmad wrote:You could wire this directly onto your charger leads:
And now it works like a charm
ibux
