Switching pre '04 R1150R to Twin Spark
bcbit01
Post by bcbit01 »
Anyone have any idea what would be required (if its possible) to convert a pre 2004 R1150R to twin spark? I know different heads, coils, leads, etc. Didn't know if the CPU would need to be swapped or just re-programmed, harnesses, etc. Maybe just too much trouble...so go buy a 2004; or maybe it can be done for reasonable $$$$, some parts searching, and some elbow grease.
priapismic
Post by priapismic »
San Jose BMW sells a twin-spark conversion kit for $495. Check it out at http://bikes.sjbmw.com/docs/service/specials.asp
Worth it? Only you can decide ...
Post by DJ Downunder »
I agree.
Why..Why..Why..........I'm glad that I have a single spark.
DJ
bcbit01
Post by bcbit01 »
Also, thanks for the link. Priap.
bcbit01
Post by bcbit01 »
$495 definitely falls into the reasonable range.
As for the last reply, why wouldn't you want twin spark? Surge elimination, better mileage are my two compelling reasons to do the mod. But I can't think of any reasons why not. Please enlighten me.
R4R&R
Donating Member #: 293
Post by R4R&R »
$495 isn't too bad if that's the total price, but why would you have it done? It will not give you any noticeable power increase, and I doubt you would see an increase in MPG. BMW stated it was for emissions/MPG, but the truth is, it was to help eliminate the surging problems that existed in some bikes (which BMW never admitted . A Techclusion is a little cheaper and can also eliminate a surge problem, with a lot less work.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
I have an 02 single spark..I can think of heaps of reasons why not.
1...Surge...what surge...I have none at all...yet I've heard of many twin sparks that do surge???.. :shock:
2...Better mileage....I don't think you will get any better mileage after converting your bike to a twin spark..(only my opinion).. #-o
I'm sure there are guys here that have had both that might know for sure.
3...Different heads..different coils..the wiring hassles..and who knows what else you may find.. :|
CycleRob might know more about all this..it sound like a big job to me.
4...Twice the cost when it's time for new plugs.. :D
I think BMW put the extra plug there more for an emission thing.
5...$500...geees!...and maybe get 2hp....plus it looks like a kit..so do you do all the work yourself..or pay even more.. :)
It's only my opinion...if you really want to do it..cool...let us know how it all goes.
DJ
bcbit01
Post by bcbit01 »
Thanks DJ. Any other owners have input? I'm buying an R1150R for sure but would rather be able to buy an '02-'03 for less money if the twin spark is not such a big deal..or if upgrading was reasonable. If these are not the case, I'll ante up for the '04..but no use spending more on an '04 when I could use that money for cases or windshields, or tires for an '02-'03 and be just as happy or more so.
mcollect
Post by mcollect »
I recently bought a 2002R it surged right from the day I bought it from the dealer. Thought about the twin spark conversion. Well being cheap and reading this forum I decided to do the valves and sync the TBs. NO surge. I used that money to buy a new Riding jacket and pants.
Michael
MG 78 LeMans
78 R100S
popgazer
Post by popgazer »
mcollect wrote:I recently bought a 2002R it surged right from the day I bought it from the dealer. Thought about the twin spark conversion. Well being cheap and reading this forum I decided to do the valves and sync the TBs. NO surge. I used that money to buy a new Riding jacket and pants.
This would be my choice , too.
To second DJ and others, the best investement is to learn how to fine tune the valves.
Nobody is sure perfect, but she practiced tirelessly !
ProductUser
Post by ProductUser »
I have a twin spark ('04) and it surges just like some of the single sparkers. However, proper maintenance (read: valves, TB sync...etc.) will reduce the surge in most cases.
ProductUser
Having SJBMW machine your heads for dual plugs means a lot of down time, so this should be a winter or my-other-bike mod. If you're unable to remove/install the cylinderheads (like most people) then you need to add the considerable cost of hiring an experienced Metric mechanic with a clean workshop and at least the BMW CD manual as a guide. If your chosen wrench has a toolbox drawer with over 6 hammers in it, or any hammer over 2 pound headweight, that's an H-D wrench and you should pass.
They ask . . . Why would you? If it coincides with a Winter DeCarbonization teardown -or- maybe a less GreenPeace, less lame, less tame camshaft & valvespring performance hop-up kit . . . then the additional $550+ USD given to SJBMW you'll end up spending (+head gaskets) will be very rewarding every time you ride your bike. Doing just the dual-plug mod alone will give you less erratic running at all engine temps and they claim 2 more HP. To take it apart just for a dual-plug upgrade IMO almost falls under the too rich, too anal, too much free time catagory.
priapismic
Rob just touched on something above that I'm surprised hadn't been mentioned before: carbon build-up in the combustion chambers.
A very good technical article in the BMW Owners News (a publication by BMWMOA - you have to join the club to get the mag) about a year or two ago gave a nice description of the twin spark concept, how it works, and why, etc. Basically, what has been stated is correct - the move to a twin spark head WAS done to comply with tighter Euro emissions standards that couldn't be met with a single spark head. However, one big benefit/side effect of the move has been reduced carbon build-up in the combustion chamber. Sorry, I don't have the article handy to give credence to the reference, but, if you want to keep your bike a long, long time, and you don't enjoy winter de-carbonization projects, and you don't want to screw around with Sea Foam or other additives that are supposed to help reduce carbon build-up, then that alone *might* be compelling enough reason to make the twin spark conversion.
Still, it's ultimately up to the owner to decide if it's worth it.
Biff's R
Donating Member #: 289
Post by Biff's R »
I have had both single and twin spark R1150Rs and I could not tell the difference while riding. Mileage is the same.
There are other things that I would spend my money on like riding gear, tires, saddlebags, and fuel.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Oilhead
Post by Oilhead »
I think the valve covers look better on the single plug too! :D
I think the early production 2002 with the aluminum valve covers(instead of the magnesium) are the most beautiful IMO.
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
jbuzbee
Post by jbuzbee »
I have a dual spark: valves done at 600 miles and then not done until 20,000 miles. NEVER had a surge problem. I seriously doubt valves / TB is the cause of surging.
Hey, I'm just reporting my experience.
James Buzbee
There was a time when a man was free to make his own way in the world . . ..
iowabeakster
Post by iowabeakster »
for 500 bucks i would buy boots, gloves, jackets, helmets, etc... or maybe take a day off work. not just a pair of plugs.
bcbit01
Post by bcbit01 »
Well gentlemen. I believe you have made the decison for me. Thanks. I'm handy enough to do all my own wrenching (except machine work) annd if some "blueprinting" is all (and I use the term all very loosely) I need to avoid the conversion cost, etc. then I can live with Sea Foaming my bike once or twice a year. I don't mind buy the '02-'03...you all take care of your bikes like surgeons (or most of you seem to). I'm sure I'd spot most of the lemons anyway. You've just made the right bike a little closer. Now....read the next post for my question that will fix me for good.........[/i]
1150929
Post by 1150929 »
Just for the record, some '03's have the twinsparks, mine was built in 03/03. Also, has the SS lines, not sure about other differences.
Rui
'03 R1150R silver w/abs,black motor,bags,backrest,givi
'00 CBR929RR
'08 Road King Classic
Did you get your bike yet?
I have an 02 for sale in Chi-town, if your looking!
