Below is a link to a simple web site I made up to illustrate how to remove the plastic side panels on the 1150R Roadster/Rockster.
It is necessary to remove the right side panel to change the rear brake fluid, clutch fluid and if you ever want to remove the canister.
Many of these panels have been broken because the person didn't know the "Trick!" Well, here is how you do it - go to this link:
http://mypage.home.mchsi.com/panel/index.html
Removing the plastic side panels - a web site
Bill Haycock - Member #78
Huntsville, AL
Huntsville, AL
