Do I really need to remove the tank ?!
John I. Stephen
Post by John I. Stephen »
Thanks to the advice on this forum I have just bought and fitted a RAM mounting kit for my Garmin 2720 sat nav. It looks great. The power comes from the external 12v socket and I have the correct cable for this. However, I was trying to see how best I could route the cable without, that is, removing the tank.
Boris Badenov from your photos of the same setup can you advise please?
Thanks guys
2002 R1150R Blue with ABS
R4R&R
Donating Member #: 293
Post by R4R&R »
I've been able to route power cables up underneath the tank without removing it but it's not as neat. Normally I'll re-do them the next time I have the tank off.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
Jonny_L
Post by Jonny_L »
I'll second that, I routed them along the side at first, then when I had to replace the battery on the bike, I re routed them under the tank nicely.
If you haven't already, do yourself a favour and get some black cable ties from B&Q, it makes it look much nicer.
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
I agree with what is said above. However, you can carefully lift the tank, without removing it, to route the wires better. You remove the black plastic cover on the right side, the really big bolt on the right side that actually holds the tank, and the two screws on each side at the rear of the tank that attach the trim panels. Put a towel at the front edge of the tank. Gently lift the rear and hold it with something. This will allow you room to route the wires. You avoid the problem area of the fragile fuel disconnects and O rings, because you are not touching them. You are also not disconnecting the breather tubes or fuel pump wires. You are not removing the oil coolers.
So you save time, and avoid potential problems, but still get a neater wire routing job.
Bob
2002 Atlanta Blue
Lifetime Member #74
Boris Badenov
Post by Boris Badenov »
John,
Initially I was also looking for an easy way to connect but eventually decided to bite the bullet and do it right.
I have wired additional fuse block to the battery and routed GPS power cord underneath the gas tank to that block.
For me it was easier then to hack into existing wiring…
"This plan was fool proof, yes! Idiot proof, no!"
texbid
Post by texbid »
YES you do.
Routing the cable by hand will pass it very close to the ignigion coils. The tank comes off prety easily ...
"As my granpappy used to say. Anything worth doing is worth doing right."
R4R&R
Post by R4R&R »
Boris Badenov wrote:John,
Ideally that's the best thing to do since you'll probably be adding more electrical accesories.
I wired up a switched fuse panel using a rely to control the power. Instead of cutting into the OEM harness for a tap to power the relay, I soldered a wire on the taillight socket. That tells the relay to power on a main feed directly connected to the positive batter cable, which in turn feeds power to the fuse panel.
Removing the tank is pretty quick and easy, so it's not that much of an inconvenience.
John I. Stephen
As usual, I thank you all for the extremely helpful replies. Lifting the tank now seems less threatening. I'll try to do a good job !
R4R&R has the best solution in using the tailight power wire to actuate the relay coil because the key in the "Park" position also "key only" powers your accessories with minimal battery drain if you need your toys to work for a time period with the engine off.
The main power can best be accessed at the starter solenoid's upper fat copper stud terminal. Easy access. I'd pull the #5 fuse for the Motronic before breaking/making any power connections and reset it after putting the fuse back in. To route the wires, tank in place, I used a 2 foot length of coathanger wire and a lot of patience to pull the wires thru where they belong. Although I strongly advise against the average owner doing it, I've added my driving lite's relay BATT wire to the fat copper stud terminal with great care, while "hot". I don't like to remove the fueltank either.
jerseygeorge
Post by jerseygeorge »
CycleRob wrote:R4R&R has the best solution in using the tailight power wire to actuate the relay coil because the key in the "Park" position also "key only" powers your accessories with minimal battery drain if you need your toys to work for a time period with the engine off.
The main power can best be accessed at the starter solenoid's upper fat copper stud terminal. with great care, while "hot". I don't like to remove the fueltank either.
I am putting a blue seas fuse box under the seat (R1150RS). I was planning on powering the box with a wire directly from the battery to the auxiliary fuse box. Then at the suggestion of a friend making a double ground connection. Why hook up at the starter versus the battery for the power supply?
