Questions on the Verholen bar risers
mikem47
Post by mikem47 »
Has anybody used the verholen bar risers for the R1200R? Is there any problems with the cables not being long enough? It looks like the clutch cable could be a little short. Can the handlebar be turned ALL the way to the left and right without the cables binding? :?:
qgaex
Donating Member #: 647
Post by qgaex »
Hi Mike
I have mounted these risers.
In my case it is the brake line which limits the position of the handlebar.
(I can tilt it towards the rider only so much.)
But I checked all cables and lines and found that it looks like none are unduly bent.
Verholen also confirmed upon request that no line has to be replaced.
Given a "sensible" positioning / tilting of the handlebar it can be turned all the way left and right.
The risers look good, fit well and make riding much more pleasant for my back.....
Cheers
qgaex
*raisedrider*
OlyVR
Post by OlyVR »
I have them and have not issues with binding etc.
I mounted my bars in the same location (rotation) as previously.
Oliver
2008 R1200GS
danstl
Cables
Post by danstl »
I have the risers, but felt the brake line was pulled much too tight. I am putting on a sliightly longer one on Thursday.
Caroanbill
Re: Cables
Post by Caroanbill »
danstl wrote:I have the risers, but felt the brake line was pulled much too tight. I am putting on a sliightly longer one on Thursday.
A word of caution: check with your dealer first.
BMW categorically rejected longer brake lines when I put bar-backs on my R1150RS. That may have been because of legal issues with THAT ABS system .. the dreaded EVO II power brakes .. but I'd still check. I had to make do with limited improvement in bar position to limit stree on the lines - despite having new braided steel lines in the bar-back kit.
My dealer is fitting the Verholen bar risers - from his perspective, for goodwill (the salesguy is simply great); from my prespective, so the accessories don't give me ANY warranty grief.
BTW, the bar-risers look great - MV Verholen is very expensive, but you do get great quality and design resolution. The Moto-Technique ones I also got (after giving up hope on) are well finished but not as resolved a design.
fly
Post by fly »
I have the risers from MV as well and have the same experience as the others - all is ok as long as the bars themselves are not rotated too much back toward the rider.
2007 R1200R (now sold)
2008 Sprint ST
2005 VRSCSE
mikem47
Post by mikem47 »
Thanks for your replies. :D
