05 1150r red rear spring
ffafp
Post by ffafp »
just purchased 05 1150r ferro blue black engine/trans. rear spring is red is it o.e. ?
NoRRmad
Donating Member #: 388
Re: 05 1150r red rear spring
Post by NoRRmad »
Can you see any markings on the shock? (Manufacturer, model number, part number, etc.?) There are a lot of red springs out there -- none from BMW original equipment, as far as I know. Perhaps a picture would help.
ffafp
Post by ffafp »
black upper body/eye,silver lower eye, cannot see other markings because of shock location. thanks for asking.
ffafp
The spring color is not what was original on the bike. OEM springs are normally taylored to a 165 pound rider(s), so someone with additional weight might have chosen to change the spring. The best bet is to ask of the person that sold you the bike.....they might have an inkling as to the answer.
Another way, if you must absolutely know, is to remove the spring and measure the K constant or pounds of force per inch of vertical travel. 8)
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Red Spring is standard on the Ferro bikes.
I have an 04 Ferro Blue. My spring is red.
NoRRmad
Post by NoRRmad »
:oops:
ffafp
Post by ffafp »
thank you everyone for the input . nice forum!
mechanic savant
Re: r1150r rear spring color
Post by mechanic savant »
Yup it's original , its a higher rate (stifer) than the std. unit .My 02 1150r had the stock rear spring & would bottom w/me the wife & luggage ..my 041150a had a red spring & almost never bottomed even under severe loads !!! NOW my 1200ra is even more gooder than either of those :lol:
mechanic savant
I answered this on the 1200r page but I'll do it again !!Yess it's original !! & if you're a larger person you'll love it .. If you go to the parts dept or fische pages of some dealers(max bmw ) you'll see it as an optional rear spring unit
DSKYZD
Donating Member #: 187
Post by DSKYZD »
Merged your post from the R1200R forum here.
JOURNEY JUNKIE #187
ffafp
Post by ffafp »
thanks for the merge!
