05 1150r red rear spring
just purchased 05 1150r ferro blue black engine/trans. rear spring is red is it o.e. ?
Re: 05 1150r red rear spring
Can you see any markings on the shock? (Manufacturer, model number, part number, etc.?) There are a lot of red springs out there -- none from BMW original equipment, as far as I know. Perhaps a picture would help.
black upper body/eye,silver lower eye, cannot see other markings because of shock location. thanks for asking.
ffafp
The spring color is not what was original on the bike. OEM springs are normally taylored to a 165 pound rider(s), so someone with additional weight might have chosen to change the spring. The best bet is to ask of the person that sold you the bike.....they might have an inkling as to the answer.
Another way, if you must absolutely know, is to remove the spring and measure the K constant or pounds of force per inch of vertical travel.
MikeCam
- Centurion Moderator!
Red Spring is standard on the Ferro bikes.
I have an 04 Ferro Blue. My spring is red.
thank you everyone for the input . nice forum!
mechanic savant
Re: r1150r rear spring color
Yup it's original , its a higher rate (stifer) than the std. unit .My 02 1150r had the stock rear spring & would bottom w/me the wife & luggage ..my 041150a had a red spring & almost never bottomed even under severe loads !!! NOW my 1200ra is even more gooder than either of those
mechanic savant
I answered this on the 1200r page but I'll do it again !!Yess it's original !! & if you're a larger person you'll love it .. If you go to the parts dept or fische pages of some dealers(max bmw ) you'll see it as an optional rear spring unit
thanks for the merge!
