R1150R Maintenance Decisions - Not because you asked
Beemeridian
Donating Member #: 477
Post by Beemeridian »
5`23
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Bottom line for me - Rotella in the engine; Redline in the tranny; Amalie in the FD. I am tired of the controversy and comfortable with these choices.
(This was a maintenance choices thread once upon a time!)
Now, has anyone ever seen a discussion of what brand of DOT 4 brake fluid provides better performance and reduced hygroscopic characteristics?
Boxer
Donating Member #: 2
Post by Boxer »
No. But I do have a related query. I don't remember the last time I bought DOT 4 fluid if it said "synthetic" on the label. Is that new and different from "regular" DOT 4 fluid? I never noticed the "synthetic" nature noted before on the label.
If they are different, are they compatible? As in mixing the 2 through ignorance. :?
Beemeridian
98
MikeCam
Post by MikeCam »
Dave,
You are redeemed!
Beemeridian
8
tekxtc
Re: R1150R Maintenance Decisions - Not because you asked
Post by tekxtc »
This is a great resource :-)
May be it can go to the Archived Maintenance Forum.
I just got the used bike and wanted to do the maintenance. The bike had 4500 miles on it with last service done by BMW dealer when the bike had 600 miles. This was in July 2005. Here is what I am planning to do.
Change:
Oil + Filter
Transmission + Final Drive Oil
Inspect and Change if applicable:
Fuel Filter
Air Filter
Spark Plugs
Measure and Adjust:
Valve clearance
Throttle bodies (just ordered the TWINMAX :-)
Make the dealer do:
ABS Bleed Test + Brake fluid changes
Is there anything that I am missing?
Ferro 2004 R1150R w/ ABS since April 2008
jfslater98
Donating Member #: 535
Post by jfslater98 »
tekxtc wrote:Inspect and Change if applicable:
Fuel Filter
Air Filter
Looks like you'll be messing about with the gas tank. While it's off, the fuel quick disconnects are an achilles heel, and should probably be replaced with aftermarket units. The Omegas get quite a lot of good press around here.
