Rear Hugger
ScottSuff
Rear Hugger
Post by ScottSuff »
Thought I'd throw out a few pics of a black non carbon fiber hugger on the R1200r. I like it better than I thought I would. Was hoping it would help keep the underside clean and I think it will work. What do you all think? Excuse the layer of dust [-X
Scott TN Hills
2008 R1200R Black
2006 Triumph Tiger
1999 BMW 650 Funduro
TT RDHS
Re: Rear Hugger
Post by TT RDHS »
Very nice! 8)
That should work well at keeping your rear clean..
Re: Rear Hugger
That looks good. It also looks like you need to clean my bike. I have a hard time with that and low cleanliness expectations.
Re: Rear Hugger
Post by deilenberger »
Scott - is that a Pilot-Road on the bike (thinking about changing from the Conti's soon..)?
ScottSuff
Re: Rear Hugger
Post by ScottSuff »
Yes,that is Pilot Roads on the bike. They have little over 2000 miles on them. Seem to handle good but I'm not a real knee dragger, so not the best authority on that. Ride feels smooth and quiet as I would think this brand would perform like.
Scott TN Hills
2008 R1200R Black
2006 Triumph Tiger
lucagoa
Re: Rear Hugger
Post by lucagoa »
Scott,
very nice! Where did you get it? Did you need to remove the tire to install it? How it goes with the shock protector?
Thanks a lot
Luca
Luca
SV650 - '02
R1200R - '07
ScottSuff
Re: Rear Hugger
Post by ScottSuff »
Well, you're closer than I am to the store that the hugger came from. I ordered it from Nippynormans in England
http://www.nippynormans.com/prodinfo.as ... &mitem=107
The install was pretty easy; had to loosen the tire to get enough room to get on one of the screws. It is a close fit next to the shock protector but no problem. The hugger was thought out and designed well I think and half the price of a carbon fiber one. Service at Nippy was good. They "dispatched it" as they said the next day and I received it on the 10th day. Not to bad for normal shipping to the states from Great Britian.
Scott TN Hills
2008 R1200R Black
2006 Triumph Tiger
PhilSB
Re: Rear Hugger
Post by PhilSB »
I fitted a hugger from Nippy Normans and had to cut some of the material from the shock dust/muck guard. When I went over a bump in the road there was a hell of a squeaking sort of noise.
Phil - from the UK with last bit of snow (for now).
ScottSuff
Re: Rear Hugger
Post by ScottSuff »
You must have ESA. I read something about a small mod if you have ESA. I don't have ESA so I really can't address it.
Scott TN Hills
2008 R1200R Black
2006 Triumph Tiger
Dan-A
Donating Member #: 613
Re: Rear Hugger
Post by Dan-A »
I like the looks of the Nippy Normans black hugger which I have as well. There was no problem installing them or any mods necessary with the Ohlins rear shock.
Dan-A
BMW MOA # 137114
BLOG: http://danzgarage.net
ScottSuff
Re: Rear Hugger
Post by ScottSuff »
Looks even better when it's clean like yours!
Scott TN Hills
2008 R1200R Black
2006 Triumph Tiger
AmostThere
Re: Rear Hugger
Post by AmostThere »
Dan-A wrote:I like the looks of the Nippy Normans black hugger which I have as well. There was no problem installing them or any mods necessary with the Ohlins rear shock.
You've probably already been asked about this BUT, how do you like the Ohlins?
2008 R1200R Granite Gray
Dan-A
Re: Rear Hugger
Post by Dan-A »
AmostThere wrote:
Dan-A wrote: You've probably already been asked about this BUT, how do you like the Ohlins?
Ohlins are a real treat once they are set up properly.
Dan-A
BMW MOA # 137114
Barbossa
Re: Rear Hugger
Post by Barbossa »
Out of curiosity where is the remote hose and adjuster for your rear Ohlins?
It would appear that the R1200R rear Ohlins kit includes that.
Dan-A
Re: Rear Hugger
Post by Dan-A »
Barbossa wrote:Out of curiosity where is the remote hose and adjuster for your rear Ohlins?
Under the seat.
Dan-A
BMW MOA # 137114
Re: Rear Hugger
ScottSuff wrote:Looks even better when it's clean like yours!
That IS one clean bike. Only the rear wheel looks used.
Dan-A
Re: Rear Hugger
Post by Dan-A »
I have a new set of Conti's to put on it, and then I will try to get it dirtier.
Dan-A
BMW MOA # 137114
famousperson
Sextuple Lifer
Donating Member #: 599
Re: Rear Hugger
Post by famousperson »
Your huggers look great. They extend over the tire a bit more than my Ilumberger. Quite frankly I am not crazy about the carbon fiber look, but I don't notice it anymore, anyway. . .
(I asked for the fiberglass model for Christmas because it's so much cheaper and equally functional but Santa brought the Ilmberger. :D )
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
Re: Rear Hugger
I'll be happy to take the nasty old thing off your hands.
