Handlebar master cylinders
Twempie
Post by Twempie »
03 R1150R Non-ABS. I've changed the brake fluid several times, but have a question that's still nagging me.
My particular Clymer manual seems to have omitted the correct handlebar position for the R1150R. Should the bike be on the centerstand or sidestand? Are the bars left, right or straight ahead? Where are the correct min and max marks? Up until now I have just bled and re-filled the system so it isn't low or overfilled, but I can't stand it any more. I need to know. :-k
Thanks.
2003 R1150R Single Spark Non-ABS
taosports
Re: Handlebar master cylinders
Post by taosports »
Centerstand
Straight ahead
Fluid level should be at the center of the window.
Remember to only use fresh, unopened DOT 4 brake fluid and don't forget to check the rear brake reservoir.
iowabeakster
Post by iowabeakster »
Here are the MIN and MAX marks...and their procedures...
Apparently no MAX mark on the clutch.
taosports
Post by taosports »
I still prefer my method of checking...bike on center stand levels at middle of window. Has worked for me for 60,000 miles. The procedure BMW suggests just doesn't make sense...or maybe it's just too complicated for my simple mind. :?
Twempie
Post by Twempie »
Thanks. Much appreciated.
iowabeakster
Michael,
Your method is closer to my own, in practice. ;)
But just for the technicality of it all,(I figured that is what Twempie was after)...I posted the long version.
taosports
Post by taosports »
iowabeakster wrote:Michael,
Ah...simple minds think alike!
:lol:
