How d'ya like this front end stand?!
The sexy K1200R!
rivi7777
Post by rivi7777 »
OK. I've been searching for a front end stand for my tire eater. I was about to pop for a Pitbull front (I have the Pitbull rear) but found the left mount point comes dangerously close to the ABS sensor. Instead, I opt for the Kern-Stabi stand - which is designed for the KR/KS. I just received it am very pleased with its simplicity, ease of use, and adjustability.
http://www.mv-motorrad.de/cosmoshop/lsh ... 63251,.htm
Then, I happen upon this for $26.00!!!
That's cheaper than the special 22mm hex key I needed to buy to remove the front wheel!
Touratech's description:
When on the centerstand, the R1200GS is very heavily weight-biased to the front. Even with the front wheel removed, it is impossible for one person to hold the front forks off the ground while installing the wheel.
The removal-jack folds in half for easier storage. Includes a plate for soft-surfaces that doubles as a brown bottle opener for after the job is done. And it can be used for a kickstand plate for parking in sand or hot asphalt.
Could this item possibly work for the KR? Very cool if in fact it'll work on the K...
Post by DJ Downunder »
Nice..do you need a second person to get it on and off... :?:...that'd be a bit of a pain.
I've been thinking about one of these for my RR... http://www.kenma.com.au/public/ven_BS.html no good for taking a wheel off though.
