http://www.mv-motorrad.de/cosmoshop/lsh ... 63251,.htm
Then, I happen upon this for $26.00!!!
That's cheaper than the special 22mm hex key I needed to buy to remove the front wheel!
Touratech's description:
When on the centerstand, the R1200GS is very heavily weight-biased to the front. Even with the front wheel removed, it is impossible for one person to hold the front forks off the ground while installing the wheel.
The removal-jack folds in half for easier storage. Includes a plate for soft-surfaces that doubles as a brown bottle opener for after the job is done. And it can be used for a kickstand plate for parking in sand or hot asphalt.
Could this item possibly work for the KR? Very cool if in fact it'll work on the K...
