Never heard of it leaking. Mine went belly-up earlier last month and I had to replace it, but it never leaked oil. I suppose if it wasn't properly sealed when replaced it could leak. The manual says to use a sealant when you screw the new one back in.
There should be a thin crush washer pre-installed on the replacement oil pressure switch.
If you use any sealant (and you should not need it because of the crush washer), use very little. Use something like Locktite 565. Sealant will affect the grounding path of the switch which will give you a false reading. When there is no path to ground, the light comes on.
jonmaddux wrote:There should be a thin crush washer pre-installed on the replacement oil pressure switch.
The switch leaked from the tip where the wire clips on, the base was OK.
R1150R 2001 Red on Z6s in England. Done 30,000 miles.
I worked in the motor trade for a number of years and this problem came up frequently. The common source of the leak is where the metal shell clamps onto the plastic body.
You're very unlucky to have 2 failures. I'n not suggesting that this is the case but the switch can be easily damaged by using the incorrect tool to tighten it.
