Foggy mask
Nakigara
Foggy mask
Post by Nakigara »
Check out this link.
http://www.kneedraggers.com/details/Res ... 02324.html
I just bought one of these at the local stealership for $19.95. It's made to fit between the foam cheekpads and the helmet lining. They are not made to fit flip up helmets like Schuberth, but if you want to fiddle with it you CAN get it to fit. I tested it in my Schuberth today and it works great! A bit of a pain in the ass to get into place initially, but worth the trouble when it's 20 deg outside!
Dan
Post by DJ Downunder »
If you have a big snease in your helmet it wont go on your visor.. :smt023
DSKYZD
Donating Member #: 187
Post by DSKYZD »
Hmmm, intersting. As it is now, I need to reapply Fogtech about every other day I ride. These trips to work in the morning when it's below freezing are really hard on the stuff. Bought my Oxtar Matrix boots from kneedraggers a few years ago.
DSKYZD
JOURNEY JUNKIE #187
new2BMW
Post by new2BMW »
I bought a foggy mask too. They work as advertised, but might be a little clostraphobic (SP?) if you swear at the traffic a lot like I do.
At about the same time, I bought a Arai XD Supermotard helmet and eliminated all of my fogging problems. The fron vent is excellent and keeps the fog away except on the worst cold, rainy days. In that case, I opn the visor one small click and the fog is gone.
Get your facts first, and then you can distort them as much as you please.
Mark Twain
mtwillyman
Post by mtwillyman »
Fog City faceshield insert works very well. YMMV.
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
I got something like this for my Shoei RF 900 helmet, and it is made by Shoei. It is not a perfect solution but it does cut down on the fog.
2002 Atlanta Blue
Lifetime Member #74
ljasonb
Post by ljasonb »
Have the foggy mask, love it. Works exactly as advertised. No fog, ever.
duke
Donating Member #: 568
Foggy and Fog City
Post by duke »
I have Shoei XR1000.
I swear by the Foggy Respro and the Fog City - I :twisted: NEVER :twisted: get mist.
And at the moment the temperature here is just above freezing.
The only sting in the tail with Foggy is having to readjust it after you take it out to wash it. It really buggers me.
cmack
Post by cmack »
I can attest to the fog city inserts. They work extremely well! I bought a bunch on closeout a while back, but since I switched to an Arai helmet, I can't use the standard inserts. Eventually, I'll have to pick some up or maybe I'll give the respro a try.
Deano
Post by Deano »
I recently purchased a Respro from RiderWarehouse. Works very well in keeping my glasses clear, which was my main problem in the cold/wet. A little tedious to get used to, but very easy to remove on nice days.
hotzuk
Foggy is a keeper but....
Post by hotzuk »
I have the mask in two of my helmets. Absolutely not foggy issues and I was a long time user of the fogshield product. My only two knocks on the product are:
1) You have to always remember to hold it while taking your lid off or the metal nose piece can scratch you up a bit.
2) If you are stuck in the heat and NOT moving, it will get hot.
Those are my two cents!
R4R&R
Donating Member #: 293
Post by R4R&R »
I've done the anti-fog stuff in the past and like Brian said, it doesn't last. It seemed like the colder it got, the quicker it would stop working. Days in the low 20's will have you re-applying it daily, but it does work. Then I got the Fog-City fog shield. Great product BUT.......It is very soft plastic and is easily scratched from cleaning. I would say buy a new one every fall/winter and remove it in the spring. The other bad part of the Fog-City shield is it slightly distorts your view, meaning it makes things a little harder to see at night and in the rain, but it's much better than fog.
I'm about due for a new helmet and supposedly the Scorpion helmets have some kind of anti fog shield built in. A co-worker has one and swears that it doesn't fog, but he doesn't ride in as cold weather as me either. They do advertise it's non-fogging capabilities.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
Deano
Post by Deano »
R4R&R wrote: I'm about due for a new helmet and supposedly the Scorpion helmets have some kind of anti fog shield built in. A co-worker has one and swears that it doesn't fog, but he doesn't ride in as cold weather as me either. They do advertise it's non-fogging capabilities.
I have one, and it will fog, given the right conditions. It may be more resistant than others, but it fogs nonetheless. Hence, my purchase of a Respro.
